zabbix_sender problem
  • Nikolaicheg
    • Feb 2009
    • 111
    Hello there!
    I'm trying to setup zabbix-server with snmptrapd. It is all ok, but zabbix_sender cant work without hostname parameter.
    root@srv-cmon:~# /usr/bin/zabbix_sender --zabbix-server 127.0.0.1 --port 10051 -I 192.168.100.23 --key snmptraps --value "SNMPv2-SMI::enterprises.8886.6.1.1.1.1.0 = STRING: "ROS_3.8.1069.ISCOM2016.70.20080704"" -vvv
    zabbix_sender [16918]: Warning: 'Hostname' parameter required
    The server should capture traps from different equipment and i cant know all hostnames of equipment.
    Searched this forum, but didnt find any solution of this problem.
  • Calimero
    • Nov 2006
    • 481
    Err... How do you expect zabbix_server to know what host the item belongs to ?
    • Nikolaicheg
      • Feb 2009
      • 111
      by the source address
      zabbix_sender -p 10051 -z localhost -I _IP_HERE_ --key bla-bla-bla
      • MrKen
        • Oct 2008
        • 652
        Originally posted by Nikolaicheg
        ..... but zabbix_sender cant work without hostname parameter.
        That's correct!
        Where do you get the ' I ' parameter from? For the hostname you need parameter -s
        Zabbix Manual 1.4 Page 69, and Zabbix Manual 1.6 Page 81, both say:
        shell> ./zabbix_sender –z zabbix –p 10051 –s LinuxDB3 –k db.connections –o
        43
        So, if you put something like "-s DefaultTrapper" for example, then ALL traps will go to the DefaultTrapper host.
        If you want to send traps to the correct host, try this link: http://pierky.wordpress.com/2009/01/...he-right-host/
        but try the DefaultTrapper first, then you'll know that it works.
        Hope that helps.
        MrKen
        • Nikolaicheg
          • Feb 2009
          • 111
          hehe
          i writen the same script, buit on perl
          idea is to find hostname by ip from sql database.
          just modified original sendtrap.pl from wiki
          • MrKen
            • Oct 2008
            • 652
            Wow, 4 smilies!!!
            I guess that means all is now okay.
            • Calimero
              • Nov 2006
              • 481
              "zabbix_sender -s $(hostname -s) ..." anyone ?
              That's one of the reasons we have the zabbix hostname matching the system hostname over here.
              Be careful, until v1.6.2 (don't know regarding pre-1.6.3) hostname is case sensitive and if the case of the reported hostname and the hostname in DB don't match, zabbix_server will discard values.
              • Nikolaicheg
                • Feb 2009
                • 111
                i dont need the system name of current pc!
                i need the hostname of switches, routers, etc... who send traps.
                see attached file.
                • Calimero
                  • Nov 2006
                  • 481
                  OK ! My bad !
