icmpping<hostaddress> for multiple interfaces
  • pikmaster
    • Feb 2009
    • 12
    Hi
    If I have a host with two interfaces (eg. eth0 and eth1), how can I check if ping goes for both eth0 and eth1?
    If I create a host with IP address assigned to one interface, i can use icmpping check.
    But when I want to check second interface, I can't do that, because icmpping does not allow me to give IP address as a parameter.
    What I did so far, I created another host which I named hostname-eth1, but I would love to have them seen as a one host, not two separate entries.
    Is there any alternative for this?
  • troffasky
    • Jul 2008
    • 640
    You could create a script that pings a host and call it from Zabbix. Bit of a kludge.
    • pikmaster
      • Feb 2009
      • 12
      This would be an external check, I'm concerned about the performance drop. Zabbix manual says not to overuse them.
