monitoring virtual interface eth0:1
  • nitram
    • Feb 2009
    I have the following problem: I'd like to monitor a created virtual interface eth0:1 on a Linux Debian OS. In zabbix, I get for the following message "not supported" in the "Status" column. What did i wrong, I tried several types of syntax.
    "net.if.in[eth0:1,bytes]"
    "net.if.in[eth01,bytes]"
    Is it possible to monitor this type of Interface? BTW I'm using zabbix 1.6.2.
    Hope you can help me.
  • sterno
    • Jan 2006
    • 24
    I don't think the kernel normally keeps any stats for individual interface aliases.
    • troffasky
      • Jul 2008
      • 640
      You'll notice from the output of 'ifconfig' or 'ip -s link' that stats aren't kept for interface aliases. You may need to install some specific IP accounting software to get stats per IP.
