Another error to add perfcounter on network interface
  • zebulon
    I have an error when I try to add a perfcounter of my network card.error message is incomplete.
    if someone could help me thanks.
    here my zabbix_agentd.log
    [04-Aug-2005 13:39:13] Unable to add user-defined counter "NetIn1" (expanded to "\Interface réseau\Octets envoyés/s\Connexion réseau Intel[R] PRO_100") to query: Impossible d'analyser le chemin d'accès du compteur. Vérifiez le format et
    and here my parameter in my zabbix_agentd.conf
    PerfCounter=NetIn1,"\Interface réseau\Octets envoyés/s\Connexion réseau Intel[R] PRO_100",30
  • zebulon
    perfcounter of network interface doesn't work on W2K3
    I have worked on my problem of perfcounter on zabbix, after some tests, I have found that perfcounter of network interface doesn't work on windows 2003 SP1. I have created a vbscript that work on 2003 in my next post I will post it.
    on windows 2000 perfcounter work correctly, just with problem on graphs.
    • selin
      • Aug 2005
      • 26
      VBScript?
      zebulon - have you posted the VBSCRIPT app to get the network traffic statistics? If so, where?
