Admin login problem
  • ltavenne
    • Aug 2005
    Admin login problem
    The solution was in
    and it was
    in db.inc.php
    remove of // in front of $DB_TYPE ="MYSQL"
    stupid thing - three weeks lost
    but it's my job too
    thanks for all
    i can't login with user admin and empty password
    i use zabbix 1.0, apache 1.3.27, php 4.3.5, mysql 3.23.56
    os is solaris 9
    importation of schema.sql and data.sql seems ok
    trapperd and suckerd work
    please help me
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Try Admin, not admin.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • ltavenne
      • Aug 2005
      not work
      i can connect to zabbix database with sqladmin
      i can see the default users
      the only thing i can't do is to connect to zabbix with my browser
      i do http://@ip
      then i receive the login page ; i notice i have the text "error: login name or password incorrect" before i write something
      • Neo
        • Jun 2005
        • 59
        Is the information in the include files (web frontend) correct?
        • ltavenne
          • Aug 2005
          contain of db.inc.php
          in fact, i follow the documentation
          \\ $DB_TYPE ="MYSQL";
          $DB_SERVER ="localhost";
          $DB_DATABASE ="zabbix";
          $DB_USER ="";
          $DB_PASSWORD ="";
          i tried with DB_USER = Admin but not solve
          then
          DB_USER = zabbix and DB_PASSWORD = zabbix but not solve
          when i modify this parameters, what process must i restart
          • Neo
            • Jun 2005
            • 59
            You don;t have to restart any process after modifying the php files.
            Just refresh your web browser properly (CTRL+Refresh if needed).
            But I don't think that thats your probelm.
            I had this same problem with Zabbix 1.0 too but the problem was with my PHP configuration.'
            GO have a look at this thread
            <edit>Which points to this thread</edit>
            • elkor
              • Jul 2005
              • 299
              I'm pretty sure DB_user and DB_password need to be set in the inc.db.php file (or whatever it is) for this to work AT ALL
              this needs to be set to the mysql user that will be using the zabbix database (or the mysql "root" account if that's the way you want to do it, although it should really be a different user)
              the Admin/nopass is just to log the front end in and is stored in the database but if the frontend can not connect to the database at all to verify this it will never work.
              The incorrect user/password is probably a php error from it trying to make a db connection and not from you entering the wrong admin user in.
              hmmm... I probably rambled on a bit there, I hope it makes sense. I'm about to go home for the day. In a nutshell: the database user and the frontend admin are two different things entirely.
              • James Wells
                • Jun 2005
                • 664
                Greetings,
                i do http://@ip
                This generally indicates two possible issues, the first being that the Zabbix frontend is unable to log into the database and the other issue is a cookie corruption in your web browser.
                For the first issue, simply update db.inc.php with the correct DB, user, and password.
                Foir the second issue, simply flush your browser's cookies, completely shut down the browser and restart it.
                Unofficial Zabbix Developer
                • ltavenne
                  • Aug 2005
                  New informations
                  i tried many things about your answers (thanks a lot) but i still have the same problem
                  i activate log into mysql and i can see that when i use the browser to connect to zabbix, there is no access to database for checking user (log is empty)
                  when i activate sucker or trapper, i see activity into log
                  i wonder if i have à good installation of apache or php
                  • ltavenne
                    • Aug 2005
                    Admin login problem resolved
                    The solution was in
                    and it was
                    in db.inc.php
                    but it's my job too
                    thanks for all
                    • zebulon
                      your link doesn't work
                      excuse,me but your link doesn't work could you modify this.
                      thanks.
                      • sinj
                        • Aug 2005
                        my solution
                        Same problem, unable to login with Admin user with empty pass.
                        Solution:
                        I forget to fill the zabbix database with data so there was no Admin user in user table.
                        So I did the 'cat data.sql | mysql -u root -p zabbix' and now I can log in.
                        OSebian.
                        DB:MySQL
                        data.sql in [zabbix-source-dir]/create/data
