Hi
I configure zabbix --with-jabber=/usr
And now my Jabber messages are in Progress.
Can anyone tell me how i can ngrep or tcpdump actions @ Port 5222 ?
i work with Zabbix since 2005 but only with Email alerts.
I try it now with Jabber but it doestn work (In Progress) no Error messages zabbix_server.log dont show errors.
I Use Zabbix 1.6.2
i Think i forgot a important step. I search the Forum but canot find the answer.
And Email alert Action are in Progress too if i compile it with Jabber support .
Without Jabber support Email Alert Actions works fine.
I Use Zabbix 1.6.2
Configuration: Detected OS: linux-gnu Install path: /usr/local Compilation arch: linux Compiler: gcc Compiler flags: -g -O2 -I/usr/include/mysql -DBIG_JOINS=1 -I/usr/include -I. -I/usr/include Enable server: yes With database: MySQL WEB Monitoring via: cURL Native Jabber: yes SNMP: net-snmp IPMI: no Linker flags: -L/usr/lib/mysql -L/usr/lib -L/usr/lib -lcurl -L/usr/lib -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lkrb5support -lresolv -lidn -lssl -lcrypto -ldl -lssl -lcrypto -lz -L/usr/lib -lnetsnmp -lm -lwrap -lwrap -lcrypto -L/usr/lib -lnetsnmp -lm -lwrap -lwrap -lcrypto Libraries: -lm -lresolv -lmysqlclient -liksemel -lcurl -lnetsnmp Enable proxy: no Enable agent: yes Linker flags: Libraries: -lm -lresolv LDAP support: no IPv6 support: no *********************************************************** * Now run 'make install' * * * * Thank you for using ZABBIX! * * <http://www.zabbix.com> * ***********************************************************
