problems with VBS Script
  • cm2000
    • Mar 2009
    • 29
    I've been testing zabbix out, and so far am very impressed. Although i have an issue and i wonder if anyone could help me please....
    I haev a VBS file set up on a windows 2003 server that checks some of our internal processes. The script returns a number, which i was hoping Zabbix could then do an action on.
    Problem is this - when testing locally with zabbix_get i get the following error...
    C:\zabbix>zabbix_get.exe -s 127.0.0.1 -k script.test
    zabbix_get.exe [2480]: Get value error: ZBX_TCP_READ() failed [An existing connection was forcibly closed by the remote host.]
    To check it wasnt my script, i replaced my script with a vbs file that just says "wscript.echo "hello" and i get the same response.
    My zabbix_agentd.conf on the win2k3 server has the following...
    UserParameter=script.test, cscript c:\zabbix\test.vbs //NOLOGO
    Any clues guys?
    Cheers,
    Tom @ CM2000
  • cm2000
    • Mar 2009
    • 29
    Fixed
    Just incase anyone has similar issues when starting out, I've found the solutions...
    #1 - When using zabbix_get.exe locally to test, ensure that 127.0.0.1 is in the allowed servers in the conf file. ()
    #2 - use wscript.stdout.write instead of wscript.echo.
    Cheers,
    Tom
