Trigger Question
  • cm2000
    • Mar 2009
    • 29
    Trigger Question
    Hi again,
    Is it possible to fire a trigger based on the result of two items?
    e.g. I have two Citrix Secure Gateways, and i check the users currently connected. I'd like to generate an alarm when the sum of both users is over 300.
    Is this possible? Or is there a better way to do citrix user counting?
    i see there is someone else having same type of issue, although no reply...
    Cheers,
    Tom
  • Jackill
    • Oct 2008
    There is no problem.
    Triggers->Create trigger->Expression ("Insert button") - and you can choose item from any host for insert into expression.
    It works
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Sure, it is absolutely possible.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
