Write own script
  • hollo
    • Oct 2007
    • 20
    Write own script
    I think this must be a feature that zabbix already support, but i cannot find a way to do it..
    Well, i have my zabbix server and i have a interbase server..
    Im doing some monitoring on my interbase server, and i have written a script which is placed on my zabbix server which i will use as an item to monitor my interbase server..
    How is this possible? I just cannot find a way to execute scripts on my zabbix server to monitor an external server..
    Can someone help?
    Best regards,
    Michael
  • stardust2678
    • Mar 2009
    I guess one way to do it is :
    1)Administration
    2)Scripts
    3)Add Script
    4) enter full path to the script and the command
    for ex:
    /bin/ping -c 3 {HOST.CONN}
    hope this helps.
    • hollo
      • Oct 2007
      • 20
      Thanks a lot for the reply.. i found the way:
      External scripts, add the correct path in zabbix_server.conf.
      Put a script into this folder..
      Use type external script as item..
      Syntax: script[parameter]
      then everything is fine.. thanks for the reply..
