Hi all,
Since I'm actually actively working on Zabbix deployment, I have a few questions regarding some Zabbix behavior :
1. I have multiple windows workstations monitored (the data comes trough by proxy).
I have a strange bug (if it is one) regarding one workstation : the data(s) collected is received by the master server (graphs works well), but in the host configuration panel, I see
Available : Not available
Error : Get value from agent failed: ZBX_TCP_READ() failed [Connection reset by peer]
Despite this error message, the workstation is being monitored correctly.
2. Is there any possible way of clearing the discovery history ?
The fact is, I made some upgrades to my discovery rules (after adding proxies), and the old discovery results are still present in the monitoring / discovery panel.
I tried to manually delete the records by excuting the following SQL statements :
DELETE FROM history
DELETE FROM history_str
DELETE FROM history_uint
but it didn't work
Any ideas ?
3. I made some screens, with all the graphs set to dynamic (so that I can see the screen's result for all the similar hosts).
The screen refreshes according to the selected host, but the problem is that I can only click on a particular graph (and see it's details) when the host is set to "default".
Is that a normal behavior
Thanks in advance
DELETE FROM history
but it didn't work
Any ideas ?
Thanks in advance
