version 1.6.3 Distributed Node
  • ataylo13
    • Feb 2007
    • 122
    I am seeing an issue when the remote node fires it sends config changes
    Remote:
    30345:20090327:180325 NODE 4: Sending configuration changes to master node 1 for node 4 datalen 11504217
    Master
    21645:20090327:180326 NODE 1: Received data from slave node 4 for node 4 datalen 11504216
    After that i see no updates between nodes... If I restart the remote node I see:
    Remote:
    31160:20090327:181939 NODE 4: Sending configuration changes to master node 1 for node 4 datalen 11506590
    Master:
    Nothing
    If I restart the master and then the remote node I will see similar logs, then nothing.
    I was seeing regular traffic between the two nodes before I added a bunch of servers to the remote node.
    Any/Ideas?
    Version : 1.8.8
    Current Configuration 1 Master and 3 Child Nodes
  • ataylo13
    • Feb 2007
    • 122
    When I restarted the master this came up in the logs on the slave:
    31160:20090327:182702 NODE 4: Error while receiving answer from Node [1] error: ZBX_TCP_READ() failed [Connection reset by peer]
    31160:20090327:182702 NODE 4: Sending history_sync of node 4 to node 1 datalen 345912
    31160:20090327:182704 NODE 4: Error while sending data to Node [1] error: ZBX_TCP_WRITE() failed [Connection reset by peer]
    31160:20090327:182704 NODE 4: Sending history_uint_sync of node 4 to node 1 datalen 345126
    31160:20090327:182704 NODE 4: Unable to connect to Node [1] error: Cannot connect to [10.34.66.195:10051] [Connection refused]
    31160:20090327:182704 NODE 4: Sending history_str_sync of node 4 to node 1 datalen 13628
    I put the Master in debug and the only thing that jumps out at me is every 10s this pops up in the logs:
    Starting sync with nodes
    Version : 1.8.8
    • borsss
      • Nov 2008
      same problem here
      hi,
      very same problem here, slave is 164 upgraded from 163, master is 164 (native)
      on slave:
      29472:20090506:123559 NODE 2: Sending configuration changes to master node 1 for node 2 datalen 13267145
      on master:
      22828:20090506:123559 NODE 1: Received data from slave node 2 for node 2 datalen 13267144
      and then nothing.
      Any ideas?...
      • xs-
        • Dec 2007
        • 393
        similar here.
        Hoping for a fix from devs soon.
        I have a child node out of sync for a month now =\
        • borsss
          • Nov 2008
          fugured it out.
          initial config sync was taking very long (I have 600 hosts).
          I was misreading the debug info..
