overview menu in 1.6.3 is empty
  • gugusg
    • Jun 2008
    • 11
    Hello all,
    i just upgraded my zabbix server to 1.6.3 and my monitoring>overview tab is totally empty ... nothing ...
    could you help me ? ;-)
  • pierre-hoffmann
    • Jan 2008
    • 133
    I've same problem but only with IE6; with Firefox it work.
    Regards,
    P.Hoffmann
    System & Network Admin.
    __________________________
    Zabbix version 1.8.1
    Hosts monitored 1300
    OS Novell SLES 10 SP2
    • 753713
      • Apr 2006
      • 137
      I have the same effect, after delete the cache in IE running zabbix
      ______________________________
      Version : 2.0.x
      Server OS: Ubuntu 12.04
      Zabbix Servers: 12
      Monitored Windows Server: ~ 1000
      • Aly
        ZABBIX developer
        • May 2007
        • 1126
        screenshot
        Zabbix | ex GUI developer
        • gugusg
          • Jun 2008
          • 11
          Here is a screenshot. Well, there is only ... nothing
          • Alexei
            Founder, CEO
            • Sep 2004
            • 5654
            It looks very much like low memory settings in php.ini.
            Alexei Vladishev
            New York | Tokyo | Riga
            My Twitter
            • gugusg
              • Jun 2008
              • 11
              i didn't modified this file, the settings are :
              max_execution_time = 330
              max_input_time = 60
              memory_limit = 16M
              should i increase the memory settings ?
              • Alexei
                Founder, CEO
                • Sep 2004
                • 5654
                Yes!
                memory_limit = 256M
                Alexei Vladishev
                My Twitter
                • gugusg
                  • Jun 2008
                  • 11
                  it's working, thank you.
                  Do you have other settings like this one that are recommanded to change ? ;-)
                  Thank you :-)
