zabbix 1.6.4 DM Node missing in frontend
  • ataylo13
    • Feb 2007
    • 122
    #16
    That fixed it for me. Thank you Aly.
    Version : 1.8.8
    Current Configuration 1 Master and 3 Child Nodes
    • side_control
      • Mar 2008
      • 37
      #17
      It resolved the issue for me as well however, my two nodes are not communicating to each other properly? Are you experiencing this?
      • ataylo13
        • Feb 2007
        • 122
        #18
        Not sure what you mean by not communicating properly. I have another thread http://www.zabbix.com/forum/showthread.php?t=12196 referencing multi node discrepancies. When monitoring the logs I see node 3 sending data more often than node 4, but not 100% I am concerned about that... yet.
        12190:20090416:130422 NODE 1: Received history from node 3 for node 3 datalen 1706
        12153:20090416:130423 NODE 1: Received history_uint from node 3 for node 3 datalen 1281
        12163:20090416:130432 NODE 1: Received history from node 3 for node 3 datalen 1888
        12195:20090416:130434 NODE 1: Received history_uint from node 3 for node 3 datalen 2573
        12182:20090416:130442 NODE 1: Received history from node 3 for node 3 datalen 2750
        12140:20090416:130443 NODE 1: Received history_uint from node 3 for node 3 datalen 2746
        12213:20090416:130447 NODE 1: Received history from node 4 for node 4 datalen 261081
        12133:20090416:130452 NODE 1: Received history from node 3 for node 3 datalen 1952
        12188:20090416:130453 NODE 1: Received history_uint from node 3 for node 3 datalen 2113
        12188:20090416:130500 NODE 1: Received history_uint from node 4 for node 4 datalen 249893
        12214:20090416:130504 NODE 1: Received data from slave node 3 for node 3 datalen 8
        12181:20090416:130513 NODE 1: Received history_str from node 4 for node 4 datalen 7236
        12149:20090416:130603 NODE 1: Received history from node 3 for node 3 datalen 11900
        12131:20090416:130604 NODE 1: Received history_uint from node 3 for node 3 datalen 13150
        Version : 1.8.8
        • side_control
          • Mar 2008
          • 37
          #19
          Well what I mean by not communicating properly. Node 1 and node 2 takes about 10 minutes to update the triggers, sometimes I don't think it's working. Node 4 and Node 1 don't update at all. Even though I see communication in the logs.
          6910:20090416:180722 NODE 4: Sending history_uint_sync of node 4 to node 1 datalen 1214
          6910:20090416:180732 NODE 4: Sending history_sync of node 4 to node 1 datalen 1987
          6910:20090416:180733 NODE 4: Sending history_uint_sync of node 4 to node 1 datalen 1393
          6910:20090416:180742 NODE 4: Sending history_sync of node 4 to node 1 datalen 1643
          6910:20090416:180743 NODE 4: Sending history_uint_sync of node 4 to node 1 datalen 1214
          6910:20090416:180752 NODE 4: Sending history_sync of node 4 to node 1 datalen 1810
          6910:20090416:180752 NODE 4: Sending history_uint_sync of node 4 to node 1 datalen 1215
          6910:20090416:180803 NODE 4: Sending history_sync of node 4 to node 1 datalen 1884
          6910:20090416:180803 NODE 4: Sending history_uint_sync of node 4 to node 1 datalen 1115
          6910:20090416:180820 NODE 4: Sending configuration changes to master node 1 for node 4 datalen 4361595
          • webdisk
            • Jan 2009
            nods showed correctly after change
            Thanks for the fix.
            now I can see all nodes.
            • Aly
              ZABBIX developer
              • May 2007
              • 1126
              #21
              Could please someone include the debug info code and post to PM or here the result so I could identify the problem
              Zabbix | ex GUI developer
              • wax66
                • Apr 2009
                • 27
                #22
                Sorry, yeah, no problem!
                DEBUG INFO: array(3) { [1]=> array(3) { ["nodeid"]=> string(1) "1" ["name"]=> string(11) "monitor-dc1" ["masterid"]=> string(1) "0" } [2]=> array(3) { ["nodeid"]=> string(1) "2" ["name"]=> string(11) "monitor-dc2" ["masterid"]=> string(1) "1" } [3]=> array(3) { ["nodeid"]=> string(1) "3" ["name"]=> string(11) "monitor-dc3" ["masterid"]=> string(1) "1" } }
                Thanks!
                -Ron
                • side_control
                  • Mar 2008
                  • 37
                  #23
                  I don't know if I should create another post, but this issue is resolved however my nodes aren't communicating properly, I feel that they are related, this started happening when I upgraded to 1.6.4. For the first few minutes I'll get an update from one node then it'll stop. Any new changes I make will not reflect on the child nodes. Attached are my log files.
                  • Aly
                    ZABBIX developer
                    • May 2007
                    • 1126
                    #24
                    Problem with missed node is resolved. See: http://www.zabbix.com/forum/showthread.php?t=12738
