1.6.2. Data from proxy are lag more 1 hour
  • kc5kse
    • Feb 2008
    • 73
    #16
    Well, I spoke to soon. Data is already an hour behind once more.
    • stemasie
      • Sep 2009
      • 18
      #17
      hmmm strange, but i think you are on the right way...
      did you completly re-created the DB? maybe take a quick change to sqlite and see if this is working.
      maybe you think about an upgrade to a newer version ...
      edit: do you use the same timeserver? you have EXACTLY the same time on proxy and server?
      • kc5kse
        • Feb 2008
        • 73
        #18
        I'm using the latest v 1.6.6. My proxies are pretty heavliy used and I think mysql is better suited. We do have some issues with ntp that we are working on but not more than a minute or minute and a half different.
        • stemasie
          • Sep 2009
          • 18
          #19
          is it the same effect when you deactive some items or clients?
          maybe they're overloaded...
          • justincase
            • Jan 2008
            Hello. I had the same problem and I did a couple of things which helped.
            - increase the number of pollers in the server config
            - change the polling frequency for the network interfaces from 5 seconds up to 30 seconds. I did this in the linux template so all hosts were immediately impacted.
            - fixed the hostnames to remove the remove the errors that looked like:
            Send list of active checks to [192.168.24.234] failed: host [host.at.mydomain.com] not found
            See http://www.zabbix.com/forum/showthre...+active+checks
            - Fixed or disabled check that cause these message:
            [host.at.mydomain.com:net.if.in[eth0,bytes]] error: Type of received value [1598548278930] is not suitable for value type [Numeric (float)]
            See http://www.zabbix.com/forum/showthread.php?t=13588
            For some of this I went to Administration->Queue and looked at the details to figure out which hosts specifically were laggy. After making all these changes things are better. I am running 1.6.6 but moving to that did not fix these.
            I hope this helps.
            /justin
            • Alexei
              Founder, CEO
              • Sep 2004
              • 5654
              #21
              I think that slow performance of Zabbix Server is the core reason of these problems. Please check that number of trappers is at 2 x <number of proxies>, also check that Zabbix Server has DB cache turned ON (parameter StartDBSyncers=1).
              Alexei Vladishev
              New York | Tokyo | Riga
              My Twitter
              • kc5kse
                • Feb 2008
                • 73
                #22
                I edited zabbix_server.conf and restarted. We'll see how it goes. One thing though; I am unable to view Details from the Queues. I don't know if it's just too much data or what.
                • kc5kse
                  • Feb 2008
                  • 73
                  #23
                  Ok, now i'm getting "History buffer is full. Sleeping for 1 second." No data is coming across at all.
                  • danpilla
                    • Oct 2009
                    I hope this helps.
                    /justin
                    I have the same problem, i make that you told, but this didn't resolve my problem, anybody can helpe me with this error?
                    19866:20091014:133458 Send list of active checks to [192.168.0.70] failed: host [ora02] not found
                    • kc5kse
                      • Feb 2008
                      • 73
                      #25
                      Bump? I've reduced the load on my Master server a good bit, but I'm still seeing an hour or more from proxies. Also, hosts I have disabled are still showing up in the log as "unable to connect...".
                      Any help would be greatly appreciated!!
