I posted this in the "Help" forum as well, Please move if it is in the incorect forum.
I have searched through the forums, however none of the solutions provided helped.
I have done the following:
Clicked "CONFIG":
Description: Email Alert
Type: mail
SMTP server: smtp.myserver.com
SMTP helo: myserver.com
SMTP email: [email protected]
I use Sendmail and checked to make sure I could send mail to the [email protected] user.
Clicked "USERS"
Under "Configuration of Users", I have my username listed and then...
Clicked "Media"
Type: Email Alert
Send to: [email protected]
Use if severity: (I highlighted all of them)
Status: Enabled
I set up the following for a trigger as a test:
Clicked "TRIGGER":
Description: Test Trigger - Telnet
Expression: {server.myserver.com:net[listen_23].last(0)}=0
Severity: High
URL: server.myserver.com:23
Clicked "ACTIONS" next to "Test Trigger - Telnet":
Send Message To: Single User
User: myusername
When Trigger Becomes: On or Off
Delay between messages (in sec)
Subject: Test Trigger - Telnet
Message: Message ...
Scope: This trigger only
When I checked through the mail log, I see the following:
Aug 11 17:21:25 server sm-mta[2127]: j7BLLPCZ002127: localhost [127.0.0.1] did not issue MAIL/EXPN/VRFY/ETRN during connection to MTA
I am not sure what is going on. Any help would be much appreciated.
Thanks!
Clicked "CONFIG":
Type: mail
Clicked "USERS"
Clicked "Media"
Type: Email Alert
Status: Enabled
Clicked "TRIGGER":
Severity: High
User: myusername
Thanks!
