Monitoring OSPF state
  • zabnew
    • Jan 2009
    Hello all,
    Somebody has any idea to monitor ospf neighbor ship using SNMP on Cisco router?
    My problem is that the format of such snmp variable will not fit in the standard supported advanced SNMP feature of zabbix.
    e.g.
    Advanced supported format is:
    <base OID of data>[“index”,”<base OID of index>”,”<string to search for>”]
    i.e. ifOutOctets["index","ifDescr","FastEthernet0/0"] ==
    ifOutOctets.1
    And an example of such OSPF state will be:
    ospfNbrState.<IP-Address>.0
    with IP-address = IP address of the neighbor
    OF course you can add those items manually one by one, but want to have a template for it that use either ifDescr or ifAlias field of the snmp variables.
    Any help will be appreciated.
    Thanks in advance.
    Regards,
    H2T
  • welkin
    • Mar 2007
    • 132
    same problem here with BGP sessions on a Juniper router. The OID are extended with both peers of the BGP session.
    e.g.
    .1.1.1.192.168.1.1.192.168.1.2
    i hope there will be a better solution than just manually add these oid's.
    • astol
      • Jul 2020
      • 9
      you want to look at ipRouteNextHop - OID: 1.3.6.1.2.1.4.21.1.7 Free RFC1213-MIB SNMP MIB Download - Free MIB Download - Search MIBs - OiDViEW
      as just looking at the neighbour won't necessarily tell you if the route has changed.
      I created a template with a single item and trigger​, basically looking at a particular next hop for the path I need and trigger on change()
