Distributed Monitoring Not Working
  • side_control
    • Mar 2008
    • 37
    I have three nodes, two works which work and one that just refuses to work.
    Issues with non working node.
    1. After adding the node, after a while it automatically removes itself, it's also missing from the zabbix.nodes table
    2. The first data transfer it will send *some* data over but stops right after that.
    3. New nodes stops logging completely but still sends alerts.
    grep NODE /tmp/* (master node)
    zabbix_server.log:  2801:20090421:133756 NODE 1: Received history from node 2 for node 2 datalen 350595
    zabbix_server.log:  2802:20090421:133819 NODE 1: Received data from slave node 2 for node 2 datalen 110
    zabbix_server.log:  2804:20090421:133908 NODE 1: Received history from node 2 for node 2 datalen 350595
    zabbix_server.log:  2802:20090421:133928 NODE 1: Received history_uint from node 2 for node 2 datalen 336608
    zabbix_server.log:  2804:20090421:133944 NODE 1: Received history_str from node 2 for node 2 datalen 464
    zabbix_server.log:  2803:20090421:133948 NODE 1: Received events from node 2 for node 2 datalen 222
    zabbix_server.log:  2803:20090421:133950 NODE 1: Received history from node 2 for node 2 datalen 351798
    zabbix_server.log:  2801:20090421:134012 NODE 1: Received data from slave node 2 for node 2 datalen 11626
    zabbix_server.log:  2805:20090421:134116 NODE 1: Received history from node 2 for node 2 datalen 351798
    zabbix_server.log:  2805:20090421:134140 NODE 1: Received history_uint from node 2 for node 2 datalen 336727
    zabbix_server.log:  2804:20090421:134151 NODE 1: Received history_str from node 2 for node 2 datalen 1520
    zabbix_server.log:  2805:20090421:134152 NODE 1: Received events from node 2 for node 2 datalen 14553
    zabbix_server.log:  2805:20090421:134154 NODE 1: Received history from node 2 for node 2 datalen 351067
    zabbix_server.log:  2804:20090421:134213 NODE 1: Received history_uint from node 2 for node 2 datalen 336667
    zabbix_server.log:  2803:20090421:134223 NODE 1: Received history_str from node 2 for node 2 datalen 554
    zabbix_server.log:  2801:20090421:134232 NODE 1: Received data from slave node 2 for node 2 datalen 7148
    zabbix_server.log:  2801:20090421:134321 NODE 1: Received history from node 2 for node 2 datalen 351663
    zabbix_server.log:  2803:20090421:134331 NODE 1: Received history_uint from node 2 for node 2 datalen 335475
    zabbix_server.log:  2801:20090421:134341 NODE 1: Received history_str from node 2 for node 2 datalen 458
    zabbix_server.log:  2801:20090421:134345 NODE 1: Received history from node 2 for node 2 datalen 351546
    zabbix_server.log:  2802:20090421:134400 NODE 1: Received history_uint from node 2 for node 2 datalen 329297
    zabbix_server.log:  2805:20090421:134408 NODE 1: Received history_str from node 2 for node 2 datalen 248
    zabbix_server.log:  2804:20090421:134414 NODE 1: Received history from node 2 for node 2 datalen 351729
    zabbix_server.log:  2805:20090421:134429 NODE 1: Received history_uint from node 2 for node 2 datalen 330067
    zabbix_server.log:  2801:20090421:134438 NODE 1: Received history_str from node 2 for node 2 datalen 386
    zabbix_server.log:  2805:20090421:134438 NODE 1: Received events from node 2 for node 2 datalen 69
    zabbix_server.log:  2805:20090421:134446 NODE 1: Received data from slave node 2 for node 2 datalen 78
    zabbix_server.log:  2803:20090421:134508 NODE 1: Received history from node 2 for node 2 datalen 352172
    zabbix_server.log:  2801:20090421:134520 NODE 1: Received history_uint from node 2 for node 2 datalen 334517
    zabbix_server.log:  2805:20090421:134529 NODE 1: Received history_str from node 2 for node 2 datalen 248
    zabbix_server.log:  2802:20090421:134535 NODE 1: Received history from node 2 for node 2 datalen 351670
    zabbix_server.log:  2804:20090421:134559 NODE 1: Received history_uint from node 2 for node 2 datalen 336728
    zabbix_server.log:  2805:20090421:134608 NODE 1: Received history_str from node 2 for node 2 datalen 600
    zabbix_server.log:  2803:20090421:134619 NODE 1: Received history from node 2 for node 2 datalen 350855
    zabbix_server.log:  2805:20090421:134633 NODE 1: Received history_uint from node 2 for node 2 datalen 336554
    zabbix_server.log:  2803:20090421:134646 NODE 1: Received data from slave node 2 for node 2 datalen 8
    zabbix_server.log:  2802:20090421:134709 NODE 1: Received history from node 2 for node 2 datalen 352072
    zabbix_server.log:  2804:20090421:134710 NODE 1: Received data from slave node 4 for node 4 datalen 4511806
    zabbix_server.log:  2801:20090421:134720 NODE 1: Received history_uint from node 2 for node 2 datalen 336853
    zabbix_server.log:  2805:20090421:134731 NODE 1: Received history_str from node 2 for node 2 datalen 464
    zabbix_server.log:  2805:20090421:134746 NODE 1: Received history from node 2 for node 2 datalen 351534
    zabbix_server.log:  2801:20090421:134758 NODE 1: Received history_uint from node 2 for node 2 datalen 336629
    zabbix_server.log:  2802:20090421:134808 NODE 1: Received history_str from node 2 for node 2 datalen 248
    zabbix_server.log:  2803:20090421:134812 NODE 1: Received history from node 2 for node 2 datalen 351256
    zabbix_server.log:  2801:20090421:134826 NODE 1: Received history_uint from node 2 for node 2 datalen 336683
    zabbix_server.log:  2803:20090421:134836 NODE 1: Received history_str from node 2 for node 2 datalen 238
    zabbix_server.log:  2803:20090421:134844 NODE 1: Received history from node 2 for node 2 datalen 351253
    zabbix_server.log:  2805:20090421:134855 NODE 1: Received history_uint from node 2 for node 2 datalen 336525
    zabbix_server.log:  2802:20090421:135343 NODE 1: Received data from slave node 4 for node 4 datalen 4511806
    zabbix_server.log:  2801:20090421:135412 NODE 1: Received data from slave node 2 for node 2 datalen 8
    zabbix_server.log:  2805:20090421:135432 NODE 1: Received history from node 2 for node 2 datalen 351719
    zabbix_server.log:  2803:20090421:135452 NODE 1: Received history_uint from node 2 for node 2 datalen 336588
    zabbix_server.log:  2805:20090421:135503 NODE 1: Received history_str from node 2 for node 2 datalen 2196
    zabbix_server.log:  2801:20090421:135509 NODE 1: Received data from slave node 2 for node 2 datalen 8
    zabbix_server.log:  2803:20090421:135549 NODE 1: Received history from node 2 for node 2 datalen 351074
    zabbix_server.log:  2803:20090421:135626 NODE 1: Received history_uint from node 2 for node 2 datalen 336622
    zabbix_server.log.old:  2147:20090421:133746 NODE 1: Received history from node 2 for node 2 datalen 350595
    Broken Node
    tail -f zabbix_server.log
      2642:20090421:134957 Executing housekeeper
      2645:20090421:134957 server #15 started [Poller for unreachable hosts. SNMP:YES]
      2647:20090421:134957 server #16 started [Node watcher. Node ID:4]
      2650:20090421:134957 server #17 started [HTTP Poller]
      2652:20090421:134957 server #18 started [Discoverer. SNMP:YES]
      2653:20090421:134957 server #19 started [Escalator]
      2621:20090421:134957 server #0 started [Watchdog]
      2621:20090421:134957 In main_watchdog_loop()
      2642:20090421:135002 Deleted 0 records from history and trends
      2647:20090421:135005 NODE 4: Sending configuration changes to master node 1 for node 4 datalen 4511807
    Any help is appreciated.
  • xs-
    • Dec 2007
    • 393
    What zabbix/database version.
    • side_control
      • Mar 2008
      • 37
      All three nodes are 1.6.4 and mysql is 5.0.45.
      • Senator
        • Feb 2009
        • 9
        Hi
        maybe you have same problem as we - http://www.zabbix.com/forum/showthre...ghlight=events
        Regards
        Tobias
