Zbx_tcp_read
  • jcesario
    • Apr 2009
    • 65
    Zbx_tcp_read
    Im receiving this error on zabbix 1.6.4 on linux 2.6:
    error: Get value from agent failed: ZBX_TCP_READ() failed [Interrupted system call]
    The key/item that this happens on seems to change every time it happens.
    Everything else on the agent works fine. Just every now and then a bunch of keys will throw this error. Ive set the number of agents to start at 10.
    There are no latency or firewall issues betweent the host and the agent. The host is a linux 2.6 system with the default template "Template_Linux" attached to it and nothing else.
    Also, In the agentd.log files I see the following right before i get the ZBX_TCP_READ errror:
    Got SIGPIPE. Where it came from???
    Can someone tell me how to troubleshoot this?
