I have insalled Zabbix 1.6.4 in Federo Linuix OS. And, it was running zabbix_server, zabbix_agend, httpd servers are fine. After displaying Login page when trying to login with Admin' and no password, It is giving following error: "ERROR: Login name or password is incorrect". I have followed following Installation steps and please help on me if I need to do anything to login here...
1. yum install gcc automake autoconf libtool make
2. # yum install php php-bcmath php-gd php-mysql httpd mysql mysql-server mysql-devel
# yum install net-snmp net-snmp-utils net-snmp-devel net-snmp-libs curl-devel mak
3. # wget http://dag.wieers.com/rpm/packages/f…l5.rf.i386.rpm
# rpm -Uvh fping 2.4-1.b2.2.el5.rf.i386.rpm
# chmod 7555 /usr/sbin/fping
4. # yum install ntp
5. /etc/init.d/ntpd start
6. useradd zabbix
7. wget http://downloads.sourceforge.net/zab…x-1.6.4.tar.gz
tar -xzvf zabbix-1.4.5.tar.gz
8. /etc/init.d/mysqld start mysqladmin -u root password
9. mysql -u root -p
mysql> CREATE DATABASE zabbix;
mysql> GRANT DROP,INDEX,CREATE,SELECT,INSERT,UPDATE,ALTER,DELET E ON zabbix.* TO mysqluser@localhost IDENTIFIED BY ‘mysqlpass’;
mysql> quit;
10.cd zabbix-1.6.4
# cat create/schema/mysql.sql | mysql -u mysqluser -p mysqlpass
# cat create/data/data.sql | mysql -u mysqluser -p mysqlpass
# cat create/data/images_mysql.sql | mysql -u mysqluser -p mysqlpass
11. ./configure -enable-server -prefix=/usr/local/zabbix -with-mysql -with-net-snmp -with-libcurl
# make install
# make clean
12. ./configure -enable-agent -prefix=/usr/local/zabbix make install
13. # echo ‘zabbix_agent 10050/tcp’ >> /etc/services
# echo ‘zabbix_trap 10051/tcp’ >> /etc/services
14. # mkdir /etc/zabbix
# cp misc/conf/zabbix_agentd.conf /etc/zabbix
# cp misc/conf/zabbix_server.conf /etc/zabbix
15. vi /etc/zabbix/zabbix_server.conf
16. DBUser=mysqluser
BPassword=mysqlpass
DBSocket=/var/lib/mysql/mysql.sock
FpingLocation=/usr/sbin/fping
17. # vi /etc/zabbix/zabbix_agentd.conf
Server=127.0.0.1,YourServerIP ---- Added my server IP
Hostname=EnterAUniqueHostNameForEachAgent ----- Added myHostName
18. # cp misc/init.d/redhat/zabbix_agentd_ctl /etc/init.d/zabbix_agentd
# cp misc/init.d/redhat/zabbix_server_ctl /etc/init.d/zabbix_server
19. In /etc/init.d/zabbix_agentd:
BASEDIR=/usr/local/zabbix
ZABBIX_AGENTD=$BASEDIR/sbin/zabbix_agentd
20. In /etc/init.d/zabbix_server:
ZABBIX_SUCKERD=$BASEDIR/sbin/zabbix_server
21. In /etc/init.d/zabbix_agentd
/sbin/chkconfig: 345 95 95 # description: Zabbix Agentd
22. In /etc/init.d/zabbix_server
/sbin/chkconfig: 345 95 95 # description: Zabbix Server
23. chkconfig –level 345 zabbix_server on ---- FAILED (this step is not working)
# chkconfig –level 345 zabbix_agentd on ---- FAILED (this step is not working)
# chkconfig –level 345 httpd on
# chkconfig –level 345 mysqld on
# /etc/init.d/iptables stop
24. cp -r frontends/php /var/www/html/zabbix
25. Edit /etc/php.ini
max_execution_time = 300
date.timezone = Asia/Calcutta
26. # /etc/init.d/httpd start
# chmod 777 /var/www/html/zabbix/conf
27. /etc/init.d/zabbix_agentd start
/etc/init.d/zabbix_server start
28. hmod 755 /var/www/html/zabbix/conf
Open Zabbix Login page but when tried with Login 'Admin' and no password, it is giving error.
It's get failed on only Step No: 22 (first and second points). Please help on it.
Remaining steps are working fine only...Please suggest me to go for further movement.
Thanks,
Siva.
6. useradd zabbix
9. mysql -u root -p
mysql> quit;
10.cd zabbix-1.6.4
# make install
# make clean
BPassword=mysqlpass
Thanks,
Siva.
