compile on debain sarge
  • michu
    • Nov 2004
    • 20
    hey all
    i try to compile zabbix on debian 3.1:
    mideb:/tmp/zabbix-1.1alpha12# ./configure --with-mysql --with-net-snmp
    config.status: executing depfiles commands
    * Now run 'make' *
    * Thank you for using ZABBIX! *
    * <http://www.zabbix.com> *
    mideb:/tmp/zabbix-1.1alpha12# make
    Making all in src
    make[1]: Entering directory `/tmp/zabbix-1.1alpha12/src'
    make[2]: Entering directory `/tmp/zabbix-1.1alpha12/src'
    make[2]: Nothing to be done for `all-am'.
    make[2]: Leaving directory `/tmp/zabbix-1.1alpha12/src'
    make[1]: Leaving directory `/tmp/zabbix-1.1alpha12/src'
    make[1]: Entering directory `/tmp/zabbix-1.1alpha12'
    make[1]: Nothing to be done for `all-am'.
    make[1]: Leaving directory `/tmp/zabbix-1.1alpha12'
    but nothing is compiled, means there are no binarys... any ideas?
    regards
    michu
  • James Wells
    • Jun 2005
    • 664
    Greetings,
    Originally posted by michu
    hey all
    You need to tell configure to enable either server or agents, otherwise, it does nothing as you see here.
    Unofficial Zabbix Developer
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Use also --enable-agent or --enable-server or both.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
