Number of running processes = 0
  • wbro1
    • Apr 2009
    • 17
    #16
    OESstatus rcnovell-ncs 15 May 14:01:13 0
    OESstatus rcnovell-nss 15 May 14:01:12 3
    this is the result with your parameters added.
    • richlv
      • Oct 2005
      • 3112
      #17
      that part you removed discards any output to stdout or stderr and returns exit code to stdout.
      most initscripts propery exit with code 0 when everything's successful & running, and some other code to indicate other states. so in the trigger you could simply check for #0 to detect that a service is not running.
      of course, if service will decide to silently die and initscript will think it's all ok, that's what the command will return, obviously
      • wbro1
        • Apr 2009
        • 17
        #18
        Thanks a lot for your service in helping us out here.
        My output in latest values looks now like below, I gues I must retrieve the statuscode discriptions from novell forums ?
        OESstatus rcnovell-ncs 15 May 14:37:19 0
        OESstatus rcnovell-nss 15 May 14:36:59 3
        OESstatus rcnovell-tomcat5 15 May 14:35:40 0
        OESstatus rcnovell-ipsmd 15 May 14:36:45 126
        OESstatus rcntp 15 May 14:35:56 101
        OESstatus rcnovell-zmd 15 May 14:36:14 127
        OESstatus rcapache2 15 May 14:36:58 126
        OESstatus rccron 15 May 14:36:58 126
        OESstatus rcndsd 15 May 14:35:54 0
        OESstatus rcnovell-httpstkd 15 May 14:35:41 1
        OESstatus rcnovell-idsd 15 May 14:37:19 126
        OESstatus rcnovell-smdrd 15 May 14:36:06 0
        OESstatus rcnovell-xregd 15 May 14:35:59 0
        OESstatus rcnovell-xsrvd 15 May 14:36:35 0
        OESstatus rcnscd 15 May 14:37:04 101
        OESstatus rcowcimomd 15 May 14:36:45 1
        OESstatus rcslpd 15 May 14:35:49 101
        OESstatus rcnxdrvd 15 May 14:35:36 127
        • richlv
          • Oct 2005
          • 3112
          #19
          that depends on how much you are interested in those. if you just want to know running/no, checking whether it's 0 would suffice, otherwise, yes, you should somehow find out what return codes are
          • wbro1
            • Apr 2009
            • 17
            #20
            Thanks again richlv
            • wbro1
              • Apr 2009
              • 17
              #21
              echo $? results differ in zabbix
              From Linux commandline I get result below
              CN02:/etc/init.d # /etc/init.d/cron status >/dev/null 2>&1; echo $?
              0
              Same thing in Zabbix results in exitcode 126
              UserParameter=OESstatus[*],$1 status >/dev/null 2>&1; echo $?
              OESstatus[/etc/init.d/cron]
              OESstatus /etc/init.d/cron 19 May 14:55:08 126
              • richlv
                • Oct 2005
                • 3112
                #22
                because zabbix user does not have the rights to execute the script. you can try adding ability to launch "/etc/init.d/cron status" for zabbix in sudoers
                • wbro1
                  • Apr 2009
                  • 17
                  #23
                  Perfect,
                  just added :
                  zabbix ALL=NOPASSWD: /etc/init.d/cron status
                  Now Zabbix returns a exitcode 0.
                  Thanks again.
