front end 1.6.4 - 1.6.5 (pre) node missing
  • neoyagami
    • Jan 2009
    • 13
    hello
    after update from 1.6.2 to 1.6.4 and updating front i end lossing a node (of two)
    if i use the front end of 1.6.2 the node is there
    any ideas?
  • Aly
    ZABBIX developer
    • May 2007
    • 1126
    Problem with missed node was in 1.6.4 in 1.6.5 this problem is resolved. So I would suggest to check your installation.
    Zabbix | ex GUI developer
    • neoyagami
      • Jan 2009
      • 13
      my instalation is fine
      the old front end (1.6.2) show the missing node. but the 1.6.4 and also 1.6.5 doesn't show it. So now im stuck in 1.6.2 (for the front end at least)
      i read the thread what you say but it seems the code of the file config.inc.php has changed between versions.(pardon my bad english)
