Make Install .... Error ( Leaving Directory )
  • bhrzk
    • May 2009
    Hi
    How can I fix it :
    I am tired of installing zabbix
    thanks .
  • tchjts1
    • May 2008
    • 1605
    #1 - What OS is this?
    #2 - Why are you installing version 1.4.1 ? 1.6.4 is the latest stable release...
    If you are installing on Linux, you could check this guide:
    http://www.zabbix.com/wiki/doku.php?...:ubuntuinstall
    • bhrzk
      • May 2009
      1 : CentOS
      2 : there is no diffent, I also tried that and got the same errors
      • bhrzk
        • May 2009
        heeeeeeeeeeeeeeelp pls .... we need this.
        • jroberson
          • May 2008
          • 124
          I would really suggest using the 1.6.4 sources as it is stable enough now for mass consumption (IMHO). Also, I didn't see an actual "error" in the screen you posted. What steps did you follow? Did "./configure <your options here>" return without errors or missing components?
          • bhrzk
            • May 2009
            you didnt see any errors ?
            so those "leaving directories" are suppose to be that way ? and they are not errors and everthing looks fine at that screen shot ?
            one more time! I got there errors in both versions. first I tried 1.6.4 and I couldnt install that, so I switch to this older version,
            so IT DOES NOT MAKE ANY Difference!
            I am using zabbix manual for installing and /configure return without any errors!
            • jroberson
              • May 2008
              • 124
              In that case, just try running "zabbix_server" and see what happens. If it doesn't run you may have to run it from the full path. You should be able to find it by using the "locate zabbix_server" or "whereis zabbix_server" command.
              • bhrzk
                • May 2009
                I tried to run zabbix_server but I got this error :
                [root@cpanel zabbix-1.6.4]# /etc/init.d/zabbix-server start Starting Zabbix server daemon: zabbix_server
                /etc/init.d/zabbix-server: line 20: start-stop-daemon: command not found
                • pesadilla
                  • Nov 2006
                  • 69
                  Some packages depend on the start-stop-daemon command which is not available in CentOS (or the dag repositories, AFAIK) but the solution is ...
