Dashboard not showing up, ERROR: Invalid URL
  • monolithic
    • May 2009
    • 21
    Hey everybody,
    I rebuilt my zabbix server, all is working, hosts are reporting data, etc. however the main screen/dashboard displays "ERROR: Invalid URL" in the system status, status of zabbix, last 20 issues and web monitoring field.
    Installation didn't have any errors or hiccups, i'm going to reboot, but anyone know what the problem can be before i start customizing hosts and templates?? Thanks in advanced!!
  • monolithic
    • May 2009
    • 21
    Here is a screen capture of the main page. If anyone can point me where to troubleshoot this, i spent the last 2 weeks building the original server only to have it wiped by a newer snapshot. i've spent my entire day rebuilding this server 2 times from the OS level up with the same issue.
    The zabbix server host shows up but the main page does not, no errors in the zabbix_server log or mysql log, so i'm not sure where to find this error, pelase help!!!!!!!
    OS is Solaris 10
    Zabbix 1.6.4
    It was working last week with the exact instructions i followed to reinstall. If anyone can help I will be in your debt!
    • Aly
      ZABBIX developer
      • May 2007
      • 1126
      Please use search! this problem already been discussed.
      P.S. just clear browsers cache.
      Zabbix | ex GUI developer
      • monolithic
        • May 2009
        • 21
        THANK YOU!!! I'm sorry, I did search for this issue and the only threads that came up were about the history displaying this error and to clear out the profiles which I did do, which did not work. Thank you again!
