Child Node not Visible in Master Node
  • praveen.kurra@tcs.com
    • May 2009
    • 10
    I am having zabbix 1.6.4 and testing distributed zabbix setup.
    i have Node1 (Master) zabbbix 1.6.4
    Node 2 (Child1) zabbbix 1.6.4
    Node 3 (Child2) zabbbix 1.6.4
    I have followd the steps in the zabbix 1.6 manually and was able to setup the Node1 Master and Node 2 (Child 1) with out issues. I can see the Child1 from master.
    When i added another child Node 3 (Child2). I am not able to see the Node 3 (Child2) from Node1 (Master) console.
    My Node 3 (Child2) server logs shows does not show any errors below are the logs
    738:20090527:221146 NODE 3: Sending history_sync of node 3 to node 1 datalen 767
    6738:20090527:221146 NODE 3: Sending history_uint_sync of node 3 to node 1 datalen 360
    6738:20090527:221159 NODE 3: Sending configuration changes to master node 1 for node 3 datalen 9
    6738:20090527:221218 NODE 3: Received data from master node 1 for node 3 datalen 9
    6738:20090527:221219 NODE 3: Sending history_sync of node 3 to node 1 datalen 2478
    6738:20090527:221219 NODE 3: Sending history_uint_sync of node 3 to node 1 datalen 1007
    6738:20090527:221222 NODE 3: Sending history_sync of node 3 to node 1 datalen 350
    6738:20090527:221222 NODE 3: Sending history_uint_sync of node 3 to node 1 datalen 65
    6738:20090527:221232 NODE 3: Sending history_sync of node 3 to node 1 datalen 772
    6738:20090527:221232 NODE 3: Sending history_uint_sync of node 3 to node 1 dat
    Node1 (Master) Logs
    15346:20090527:221053 NODE 1: Received history from node 3 for node 3 datalen 813
    15344:20090527:221053 NODE 1: Received history_uint from node 3 for node 3 datalen 322
    15339:20090527:221103 NODE 1: Received history from node 3 for node 3 datalen 806
    15346:20090527:221103 NODE 1: Received history_uint from node 3 for node 3 datalen 317
    15341:20090527:221113 NODE 1: Received history from node 3 for node 3 datalen 730
    15339:20090527:221113 NODE 1: Received history_uint from node 3 for node 3 datalen 313
    15343:20090527:221123 NODE 1: Received history from node 3 for node 3 datalen 847
    15341:20090527:221123 NODE 1: Received history_uint from node 3 for node 3 datalen 490
    15344:20090527:221133 NODE 1: Received history from node 3 for node 3 datalen 733
    15343:20090527:221133 NODE 1: Received history_uint from node 3 for node 3 datalen 444
    Need Help to fix this issue.
    Regards
  • Aly
    ZABBIX developer
    • May 2007
    • 1126
    grab frontend from our nightly builds ZBX pre1.6.5
    Zabbix | ex GUI developer
      • May 2009
      • 10
      It worked.
      Thank you very much Ally. It worked after using the frontends of zabbix 1.6.5.
      Regards
      Praveen
