SNMP Monitoring an Astaro Firewall (v7)
  • Danny
    • May 2009
    I tried monitoring an Astaro firewall over SNMP.
    Basically I want to monitor CPU, RAM and Swap.
    When I executed 'snmpwalk -v2 -c trapname hostname > results.txt' I got a lot of SNMP-names.
    One of the names is 'hrMemorySize.0' whitch has got the integer value of '1036344 KBytes' - the Astaro has got 1GB RAM so the value is true.
    Then I defined an element in Zabbix with the snmp-key 'hrMemorySize.0'. Zabbix output of that value is: 3,44K.
    After that I defined an element in Zabbix with the snmp-key 'UCD-SNMP-MIB::memTotalReal.0' - Zabbix output of that value is: 3858735822.
    Did anyone tried to monitor an Astaro or got a klue why the output values are this strange?
    I tried for hours to get the value '1036344'....
    Thanks in advance,
    Danny
  • richlv
    • Oct 2005
    • 3112
    show full item configuration, especially units & multiplier used
    • Danny
      • May 2009
      Here is the Item Config:
      It's very strange that the memory value is increasing - when I use 'snmpget -v2c -c scs 172.31.8.1 HOST-RESOURCES-MIB::hrMemorySize.0' I always get a value of HOST-RESOURCES-MIB::hrMemorySize.0 = INTEGER: 1036344 KBytes.
      • troffasky
        • Jul 2008
        • 640
        You're polling the ifInOctets on the first interface, hence the continually incrementing value. Change the SNMP OID field.
        • richlv
          • Oct 2005
          • 3112
          yeah, what he said
          for the record, 'key' for snmp items does nothing, it's just something you can reference in triggers. snmp oid is the important value, showing what entry from the mib to retrieve
          • troffasky
            • Jul 2008
            • 640
            The key field should be hidden and just made equal to the OID field, accessible via an 'Advanced...' screen or similar.
            • richlv
              • Oct 2005
              • 3112
              well... it would increase trigger length considerably, and readability migh decrease.
              though i like the idea about it being set to oid by default, and still accessibly with some control to enter custom key.
              • troffasky
                • Jul 2008
                • 640
                For you, perhaps! Every time I create an object to monitor, I just paste the OID into the key field. It would probably be a 10 minute job to create a bit of Javascript that does it for me.
                • Danny
                  • May 2009
                  Thanks for your quick answers.
                  I'm new to snmp, so I mixed up the settings.
                  Now it works fine.
