Some troubble with mysql while installing zabbix
  • hiacine
    • May 2009
    • 18
    I just installed zabbix on CentOs 5.3
    I folow this method :
    In the setup web interface, when I click on the finish button I have this error :
    # mysql_fetch_array(): supplied argument is not a valid MySQL result resource[/etc/zabbix/db.inc.php:411]
    # Error in query [select n.nodeid,min(r.permission) as permission, g.userid from nodes n left join rights r on r.id=n.nodeid and r.type=0 left join users_groups g on r.groupid=g.usrgrpid and g.userid=0 where n.nodeid in (0) group by n.nodeid, g.userid order by nodeid desc, userid desc, permission desc] [Table 'zabbix.nodes' doesn't exist]
    My Mysql user is root
    Loggin is impossible.
    And I'm unable to replay the zabbix web setup
  • pesadilla
    • Nov 2006
    • 69
    mysql -uroot -p zabbix
    type "show tables;"
    • hiacine
      • May 2009
      • 18
      Yes,
      Table is empty.
      I've got mysql version : 5.0.45
      But when i try to create the tables manualy from zabbix's source,
      it tell me that there is an error in syntax.
      • hiacine
        • May 2009
        • 18
        for example :
        with this request whish is in mysql.sql
        CREATE TABLE slideshows (
        -> slideshowidbigint unsignedDEFAULT '0'NOT NULL,
        -> namevarchar(255)DEFAULT ''NOT NULL,
        -> delayintegerDEFAULT '0'NOT NULL,
        -> PRIMARY KEY (slideshowid)
        -> ) type=InnoDB;
        i've got this error
        ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'unsignedDEFAULT '0'NOT NULL,
        delayintegerDEF' at line 2
        • hiacine
          • May 2009
          • 18
          The méthod was not good for creating tables.
          here is the good method :
          mysql -u root -p zabbix < /home/zabbix/zabbix-1.4/create/schema/mysql.sql
          mysql -u root -p zabbix < /home/zabbix/zabbix-1.4/create/data/data.sql
          mysql -u root -p zabbix < /home/zabbix/zabbix-1.4/create/data/images_mysql.sql
          Now it works
          thanks
