SNMP value problem
  • shaihi
    • Oct 2004
    • 17
    SNMP value problem
    (1)I have aproblem with one item which returns a normal value ( -490 ) when I manually do "snmpget..." and zabbix returns 4294966806. It's happening only on one client - the others work fine. What could be the problem?
    (2)Also when I start zabbix_suckerd I get snmpget: Timeout but I can't see about what ( which item, which host...), so if there's a place to configure zabbix to spew more info on the snmp messages - where is it, and if there isn't maybe there's a chance of adding one???
    Thanks in advance,
    Shai
  • obstler
    • Oct 2004
    • 30
    This sounds like a signed/unsigned prob. The number you're getting is 2^32 -490, exactly what happens when a signed 32bit integer is interpreted as an unsigned one. Probably the SNMP code isn't expecting signed/negative values, but that is something for Alexei to respond to...
    tom.
    • riegersteve
      • Oct 2004
      • 68
      in zabbix_suckerd.conf change the logging from 1 to 3 or 4 or 5
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Type?
        What's SNMP type of the OID? COUNTER64?
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
        • shaihi
          • Oct 2004
          • 17
          SNMPv2-SMI::enterprises.1449.10.2.1.6.1.1.1.11.1 = INTEGER
          and I set the information for debug level, but still all I get is snmpget: Timeout...
          No new info in the zabbix_suckerd.log
