gcc -DZABBIX_DAEMON -g -O2 -I/usr/local/include -I/usr/local/lib/libsqlora8/include -L/usr/local/lib -lsqlora8 -o zabbix_server zabbix_server-actions.o zabbix_server-operations.o zabbix_server-events.o zabbix_server-zlog.o zabbix_server-server.o alerter/libzbxalerter.a dbsyncer/libzbxdbsyncer.a discoverer/libzbxdiscoverer.a pinger/libzbxpinger.a poller/libzbxpoller.a housekeeper/libzbxhousekeeper.a timer/libzbxtimer.a trapper/libzbxtrapper.a nodewatcher/libzbxnodewatcher.a utils/libzbxutils.a httppoller/libzbxhttppoller.a watchdog/libzbxwatchdog.a escalator/libzbxescalator.a ../../src/libs/zbxsysinfo/libzbxserversysinfo.a ../../src/libs/zbxsysinfo/linux/libspecsysinfo.a ../../src/libs/zbxsysinfo/common/libcommonsysinfo.a ../../src/libs/zbxsysinfo/simple/libsimplesysinfo.a ../../src/libs/zbxlog/libzbxlog.a ../../src/libs/zbxnix/libzbxnix.a ../../src/libs/zbxsys/libzbxsys.a ../../src/libs/zbxconf/libzbxconf.a ../../src/libs/zbxemail/libzbxemail.a ../../src/libs/zbxsms/libzbxsms.a ../../src/libs/zbxdbhigh/libzbxdbhigh.a ../../src/libs/zbxdb/libzbxdb.a ../../src/libs/zbxdbcache/libzbxdbcache.a ../../src/libs/zbxcommon/libzbxcommon.a ../../src/libs/zbxcrypto/libzbxcrypto.a ../../src/libs/zbxcomms/libzbxcomms.a ../../src/libs/zbxjson/libzbxjson.a ../../src/libs/zbxserver/libzbxserver.a ../../src/libs/zbxicmpping/libzbxicmpping.a -lm -lresolv
/usr/bin/ld: skipping incompatible /usr/local/lib/libsqlora8.so when searching for -lsqlora8
/usr/bin/ld: skipping incompatible /usr/local/lib/libsqlora8.a when searching for -lsqlora8
/usr/bin/ld: cannot find -lsqlora8
collect2: ld returned 1 exit status
make[3]: *** [zabbix_server] Error 1
make[3]: Leaving directory `/appdata/install/zabbix-1.6.4/src/zabbix_server'
make[2]: *** [install-recursive] Error 1
make[2]: Leaving directory `/appdata/install/zabbix-1.6.4/src/zabbix_server'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/appdata/install/zabbix-1.6.4/src'
make: *** [install-recursive] Error 1
