Trouble enabling SNMP monitoring
  • Nasso
    • Jun 2009
    Hi guys,
    Initially, I configured Zabbix without the --with-net-snmp switch. I'd like to now enable this feature but can't seem to get it right. Can you guys take a look? I'm running SUSE Linux Enterprise Server 10 SP1 (i586) and have installed the following packages:
    net-snmp-5.3.0.1-25.15
    net-snmp-devel-5.3.0.1-25.15
    tcpd-7.6-731.2 (installed by default)
    tcpd-devel-7.6-731.2
    Here's what I've done...
    /etc/init.d/zabbix_server stop
    /etc/init.d/mysql stop
    /etc/init.d/snmpd stop
    ./configure --enable-server --enable-agent --with-net-snmp --with-mysql --with-libcurl
    make install
    /etc/init.d/zabbix_server start
    /etc/init.d/mysql start
    /etc/init.d/snmpd start
    No errors are generated. The thing is, on the web console I still see 'Support of SNMP parameters was not compiled in'. So I check the zabbix_server.log.
    12797:20090604:155323 **** Enabled features ****
    12797:20090604:155323 SNMP monitoring: NO
    12797:20090604:155323 WEB monitoring: YES
    12797:20090604:155323 Jabber notifications: NO
    12797:20090604:155323 ODBC: NO
    12797:20090604:155323 IPv6 support: NO
    12797:20090604:155323 **************************
    That’s weird! I check the config.log file which contains the following SNMP specific lines and looks fine?
    SNMP_CFLAGS=' -I/usr/include/rpm -I. -I/usr/include'
    SNMP_CPPFLAGS=''
    SNMP_LDFLAGS=' -L/usr/lib -lnetsnmp -lcrypto -lm -L/usr/lib -lwrap -lcrypto'
    SNMP_LIBS='-lnetsnmp '
    #define HAVE_SNMP_SESSION_LOCALNAME 1
    #define HAVE_NETSNMP 1
    #define HAVE_SNMP 1
    #define SNMP_NO_DEBUGGING
    I’m stumped. Could it be a problem with 'make' or 'install'? Am I being a complete idiot. Hope someone can help.
    Nasso
  • MrKen
    • Oct 2008
    • 652
    As well as net-snmp and net-snmp-devel, you probably need net-snmp-utils and net-snmp-libs.
    MrKen
    • caarts
      • Aug 2008
      • 37
      I have several Suse 9.1/3 and 10.0 servers and they all give trouble installing/upgrading Zabbix . Upgrading from older versions to even 1.4.6 or 1.6.4 are problematic. net snmp/mysql libraries etc etc
      Make sure you also have mysql-devel package installed, I am going to upgrade to suse 10.1 and see what goes.
      • troffasky
        • Jul 2008
        • 640
        Check where 'make install' has put the Zabbix binaries and look at that init script to see what its $PATH is. It may even be hard coded. I suspect the init script is calling an old Zabbix binary, hence it not reflecting the configure options you selected. Compare the file size/timestamp on the zabbix binaries in the build directory and in the path. You could even md5sum them to see if they differ.
        Some commands you may find useful:
        which zabbix
        chkdupexe | grep zabbix
        md5sum filename
        • Nasso
          • Jun 2009
          SOLVED! Trouble enabling SNMP monitoring
          Thank you all for the help! troffasky takes the prize with his post.
          Looks like the binaries weren't being written to my binaries folder /opt/zabbix/bin. They were being written to the old location
