is this an error or I'm doing something wrong ?
  • hiacine
    • May 2009
    • 18
    I everybody,
    I installed zabbix 1.6.4 on centos 5.3, with mysql.
    Following this way : http://www.muck.net/?p=16
    But my server does not want to start.
    on my centos the path of zabbix_server and zabbix_agentd is /usr/local/zabbix/sbin/
    but in the source it's $BASEDIR/bin/zabbix_...
    I'v change to $BASEDIR/sbin/zabbix_...
    on the two files,
    now it works
    My Basedir is BASEDIR=/usr/local/zabbix
  • richlv
    • Oct 2005
    • 3112
    as it is noted at the beginning of that howto, binary path has changed since. if it works for you after that change, that's fine
    • hiacine
      • May 2009
      • 18
      ok
      thanks .
