Jabber Connection Timeout Issue in 1.6.4
  • manfro
    • Jun 2006
    • 25
    it seems that openfire jabber server drops connection and zabbix_server doesn't reconnect. So after a while no jabber message is sent.
    I looked around and I found a fix that modifies the zabbix behaviour. Simply it adds a call to disconnect method for any message sent.
    It works but it doesn't seem to me the best solution.
    diff -ruN zabbix-1.4.2.orig/src/libs/zbxjabber/jabber.c zabbix-1.4.2/src/libs/zbxjabber/jabber.c
    --- zabbix-1.4.2.orig/src/libs/zbxjabber/jabber.c	2007-08-21 16:18:01.571989816 +0600
    +++ zabbix-1.4.2/src/libs/zbxjabber/jabber.c	2007-08-24 10:55:01.473736104 +0600
    @@ -468,6 +468,9 @@
    		zabbix_log(LOG_LEVEL_WARNING, "%s", error);
    +	disconnect_jabber();
    +	zabbix_log( LOG_LEVEL_DEBUG, "JABBER: disconnecting");
    	return ret;
    Is it already scheduled a release that fixes this issue in a better way ?
  • manfro
    • Jun 2006
    • 25
    1.6.5 solves this issue?
    Hello, I found in 1.6.5 release note this changelog entry:
    [ZBX-884] fixed sudden stop of Jabber notifications
    does it mean that this bug is definitely closed?
    Thank you guys.
    Manfredi
