Zabbix unable to retrieve latest data from proxy monitored hosts
  • meng-kong
    • Apr 2009
    I have a few windows server residing in DMZ and being monitored via proxy. I'm able to manually retrieve key value of host from proxy using zabbix_get command, however, zabbix frontend did not reflect any latest data of the monitored host. Any suggestion?
  • richlv
    • Oct 2005
    • 3112
    proxies connect to the zabbix server. make sure proxy is correctly configured in zabbix frontend, host is set to use that proxy and proxy can connect to zabbix server (port 10051)
    • kc5kse
      • Feb 2008
      • 73
      I'm having a similar problem. The zabbix front-end is not showing any latest data from 1 particular proxy. This happened after a power loss that exceeded UPS battery time. I know the proxy is working properly by viewing the log. In fact, I can delete hosts from the front-end and I can see it propogate down to the proxy. However, If I re-add that host back, it never shows up on the proxy nor the front-end.
      I've verified proper connectivity between server and proxy. What can I look for? tcpdumps on both machines showed traffic to and from.
      I haven't gotten to the point of pulling my hair out but it's close
