WEB (HTTP) server is running: Down (0)
  • rokka
    • Jun 2009
    • 15
    zabbix agent can't check Apache service on Centos 5.2
    In frontend I see:
    "WEB (HTTP) server is running Down (0)"
    For other servers with opensuse it works perfect.
    #/opt/zabbix/zabbix_agent -V
    ZABBIX Agent v1.6.4 (3 April 2009)
    Compilation time: Jun 16 2009 09:51:21
    #uname -a
    Linux smtproxy0 2.6.18-92.1.17.el5PAE #1 SMP Tue Nov 4 14:17:52 EST 2008 i686 i686 i386 GNU/Linux
    # cat /etc/redhat-release
    CentOS release 5.2 (Final)
    I tried to define different items:
    net.tcp.service[apache]
    net.tcp.service[httpd]
    net.tcp.service[http]
    zabbix server logs:
    13270:20090618:094917 Item [smtproxy0.net.tcp.service[apache]] error: Not supported by ZABBIX agent
    Well, ok, there is no apache service.
    But why httpd service can't be checked on Centos? Agent logs are empty.
  • richlv
    • Oct 2005
    • 3112
    is apache listening on localhost ? by default zabbix checks localhost, so either make apache to listen on localhost, or specify correct ip for the item key
    • rokka
      • Jun 2009
      • 15
      Thank you for the information, it helped.
