I just upgraded to 1.6.5, and some of my triggers no longer function as they did before.
Now, when an item returns a bad value, the trigger immediately, it doesn't wait the defined number of counts before alerting.
Before, my trigger would only fire if X item had N number of failures, and only return to normal after N number of successfull returns.
Now, it fires right away, but it will return after N successes. Half right, but not all the way.
Here is an example trigger:
({Template_Merak:net.tcp.service[smtp].max(#5)}=0)|(({TRIGGER.VALUE}=1)&({Template_Merak :net.tcp.service[smtp].min(#5)}=0))
Any ideas?
Any ideas?
