Hi all,
I have searched all the whole forum and many people seem to have that "xxx is unreachable"-problem in fact that the machine is alive, the agent is listening on his port (telnet-check) - in short: everything is fine.
We have this issue too, raising randomly on nearly every machine we monitor.
- Sometimes it goes away by restarting the agent in one step
- sometimes I have to stop the agent, wait several minutes and then restart the agent
- sometimes I have to set the machine "not monitored" and "monitored" again in zabbix gui
- sometimes none of the solutions above work - it still remains unreachable for days, even if the whole machine gets rebooted
A given workaround not to use unreachable and using the ping-check gives me some headache: I have to set very much dependencies from all the triggers pointing to the ping-trigger which I'd like to avoid...
Playing around with the timout-variables (unreachable/unavailable-delays) in zabbix_server.conf also doesn't help anything.
It's going across our installation since v. 1.4.6 in all combinations of server and agent-versions.
How is the unreachable-trigger made (some internal calulations - but which)? What has to happen to get it raising - and make it ok again?
Does anybody have a solution?
