Latest data Graph summary values convergence
  • stan.vasiljev
    • Jan 2008
    • 28
    During testing of Zabbix trapper items I found some convergences in summary values of item data graph and actual item data values.
    On the simple graph of item I saw flat line at ~85 KB level and interesting summary:
    [all] [min:76.83 KB max:90.71 KB last:85.08 KB]
    But, when I switched it from "Graph" to "500 latest values"
    2009-06-24 13:21:06 1245864066 92890
    2009-06-24 13:21:06 1245864066 89789
    2009-06-24 13:21:06 1245864066 78678
    Line was flat, because of all 3 values were inserted at the same time, but why the last: = 85.08 KB on graph's summary instead of 90.71 KB ?
    Version info:
    zabbix_server -V
    ZABBIX Server (daemon) v1.6.5 (revision 7442) (3 April 2009)
  • richlv
    • Oct 2005
    • 3112
    how large was the displayed period ?
    if it was long enough, trend values were used for graphing, and those are calculated per hour
    • stan.vasiljev
      • Jan 2008
      • 28
      displayed period = 2 hours 30 min - from 2009-06-24 11:13 till 2009-06-24 13:40
      At this period were received 3 values (they listed in first post). Last value was 92890 (90.71 KB) and it was maximum value and it was correctly displayed in summary:
      But why "last:" in summary = 85.08 KB instead of 90.71 KB
      • richlv
        • Oct 2005
        • 3112
        ok, i believe zabbix does not have sub-second precision, thus ordering for three values, received in the same second, is undefined. i wouldn't be surprised if refreshing the graph/latest values would change the outcome
        • stan.vasiljev
          • Jan 2008
          • 28
          Today I can see equal picture - values, graph and summary are the same as for yesterday. No changes at all.
          Main reason of my post - to understand why graph's summary decide to show wrong last value, if we have 3 values, received in one time, and have correct order on "500 latest values" with the correct latest value
          • richlv
            • Oct 2005
            • 3112
            how do you determine which is "correct" latest value if they all have identical timestamps ?
            • stan.vasiljev
              • Jan 2008
              • 28
              I sent it manually by zabbix_sender, so I know order of values and "500 latest values" page has correct order - equal to send order.
              • richlv
                • Oct 2005
                • 3112
                that's not what i meant
                if all values have the _exact_ same timestamp, how should zabbix determine their order ?
                the fact that they are ordered as you think is correct somewhere can be considered a coincidence (or maybe data is sorted by index somewhere, but that doesn't change the fact that these values have arrived simultaneously for all zabbix cares).
                • stan.vasiljev
                  • Jan 2008
                  • 28
                  Actually "last:" value in summary line of the simple item graph is calculated as average of all values received at the last clock.
                  Initially I had souce values:
                  and "last:" = 85.08 KB
                  But when source value has been updated to this:
                  | itemid | clock | value |
                  | 22162 | 1245864066 | 8678 |
                  | 22162 | 1245864066 | 89789 |
                  | 22162 | 1245864066 | 92890 |
                  "last:" became = 62.29 KB.
                  So, that is why that thread has been created - to understand implicit logic of graph summary.
                  There is source of "last:" function:
                  function getLastValue($num){
                  $data = &$this->data[$this->items[$num]['itemid']][$this->items[$num]['calc_type']];
                  if(isset($data)) for($i=$this->sizeX-1;$i>=0;$i--){
                  if(isset($data->count[$i]) && ($data->count[$i] > 0)){
                  switch($this->items[$num]['calc_fnc']){
                  case CALC_FNC_MIN: return $data->min[$i];
                  case CALC_FNC_MAX: return $data->max[$i];
                  case CALC_FNC_ALL: /* use avg */
                  case CALC_FNC_AVG:
                  default: return $data->avg[$i];
                  return 0;
                  Maybe, in some circumstances, "last:" can be max or min value of array of values received simultaneously.
                  I think I got the answer on my initial question
                  • richlv
                    • Oct 2005
                    • 3112
                    interesting information, thanks.
                    so it means if there are multiple values in the same second and average is graphed, 'last' will show average from all these values, right ?
                    i believe this is mostly a theoretical situation as you probably won't receive many values in a single second in a real environment
                    • stan.vasiljev
                      • Jan 2008
                      • 28
                      I agree, that It's theoretical for Zabbix agent&SNMP items polling.
                      But for trapper items it's real situation. Because of traps can come simultaneously - they don't have polling interval
                      Simple example - if you will use zabbix_sender to send data to zabbix server using -i option (batch input from file) - most of values will be inserted with the same clock values - you will get one or more arrays of simultaneous values.
