Problem with non workin properly frontend.
  • marcin
    • Jun 2009
    Hello!
    I have installed Zabbix in server with Directadmin.All went rather ok with some small fixed issues but now frontend is not working correctly
    Some links are working ok like Dashboard:
    ZABBIX server is running Yes -
    Number of hosts (monitored/not monitored/templates) 43 0 / 1 / 42
    Number of items (monitored/disabled/not supported) 0 0 / 0 / 0
    Number of triggers (enabled/disabled)[true/unknown/false] 0 0 / 0 [0 / 0 / 0]
    Number of users (online) 2 2
    Required server performance, new values per second 0 -
    And some hang. Like Configuration->Hosts, Triggers,Items.. when I click on them browser is doing some job endless..
    What can be the issue? Thank you.
  • marcin
    • Jun 2009
    It started working.. but reason remains unknown..
    • kati0901
      • Aug 2021
      Hello, this publication is old but I cannot find more information about it, I am trying to install it, I could with the agent but the triggers, applications and items are complicated, will you have any help that you can give me? Thank you.
