graphs are not working right with 1.6.5
  • jmanzer
    • Jun 2006
    • 16
    I have a GUI issue.
    I have an issue where graphing under latest data requires me to slide the horizontal scrollbar slightly to the left in order for any data to show.
    I have to do the same thing under Monitoring->Graphs as well. Monitoring->screens actually repeats the behavior also.
    I checked the time on each of my zabbix systems and web client and they are all synch'd. I cannot figure out why this is happening. Does anyone have any suggestions on what it could be?
  • Aly
    ZABBIX developer
    • May 2007
    • 1126
    PHP time settings?
    Zabbix | ex GUI developer
    • jmanzer
      • Jun 2006
      • 16
      php time settings is date.timezone = US/Arizona
      also, this is php4. i just realized a dev/test vm instance i have running this same version of zabbix doesn't have this issue. it is running php5. Do you think that could be it? I'm updating php on this troubled system today.
      update: I upgraded to php5 and some gui issues did go away but i still have the issue of the scrollbar defaulting to ther future and not the present and one click on the left arrow of the scroll bar fixes the no data issue. my dev instance of zabbix doesnt do this though.
      I just noticed a time difference in the front end for prod. fixed that and graphing now seems to work.
      and a bit later it is confirmed everything is working fine now. the issue was indeed time synch issue between front end and db. thanks.
