Network Map not displaying
  • morgolis
    • Oct 2004
    • 33
    I had to change a few things on my server, namely i downgraded from Apache 2.0.51 to Apache 1.3.33.
    I'm running MySQL 4.1.7-0 and PHP4 (I compiled PHP4 and Apache from source)
    It's up and running, i can get to the webpage and do pretty much everything except it doesn't show the network graphs, screens or any type of graphic.
    Checked the error_logs and nothing there nor are there any errors or messages in /var/log/messages.
    I have other websites working that use PHP with no issues. Any ideas?
  • shaihi
    • Oct 2004
    • 17
    did you include the gd module?
    check this link on how to install the apache and php
    Guide on building and installing PHP with Apache 2 webserver software from source.
    Shai
    • morgolis
      • Oct 2004
      • 33
      i compiled apache with --enable-shared=max, --with-mysql and --with-apxs.
      Also, apache version i'm running is 1.3.33, not apache2.
      Is there a line in the apache config that shows gdbm? Is it a loaded module?
      These are the modules that are loaded in my httpd.conf:
      LoadModule env_module libexec/mod_env.so
      LoadModule config_log_module libexec/mod_log_config.so
      LoadModule mime_module libexec/mod_mime.so
      LoadModule negotiation_module libexec/mod_negotiation.so
      LoadModule status_module libexec/mod_status.so
      LoadModule includes_module libexec/mod_include.so
      LoadModule autoindex_module libexec/mod_autoindex.so
      LoadModule dir_module libexec/mod_dir.so
      LoadModule cgi_module libexec/mod_cgi.so
      LoadModule asis_module libexec/mod_asis.so
      LoadModule imap_module libexec/mod_imap.so
      LoadModule action_module libexec/mod_actions.so
      LoadModule userdir_module libexec/mod_userdir.so
      LoadModule alias_module libexec/mod_alias.so
      LoadModule access_module libexec/mod_access.so
      LoadModule auth_module libexec/mod_auth.so
      LoadModule setenvif_module libexec/mod_setenvif.so
      LoadModule perl_module libexec/libperl.so
      LoadModule php4_module libexec/libphp4.so
      Suggestions?
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Do you have support of GD compiled in PHP4? Use PHP function phpinfo(); to check this.
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
        • morgolis
          • Oct 2004
          • 33
          Problem Resolved
          In order to get gd installed from PHP, you can't just use the --with-gd switch, you must also include --with-zlib to include the zlibraries.
          I'm up and working now. Thanks for the help Alexei
