zabbix failing to connect
  • rodelapena
    • Mar 2007
    • 22
    zabbix is failing to query the mysql database with this error:
    Query failed MySQL server has gone away
    but it doesnt fall, only doenst do all the querys, only a few, i can see the state of some hosts, but not all.
    i read the forum about this behavior but in my case zabbix continues up making querys to mysql.
    i have
    centos 5.3 64 bits
    mysql Ver 14.12 Distrib 5.0.45, for redhat-linux-gnu (x86_64) using readline 5.0
    zabbix 1.6.5 innodb engine with indexes
    please tell me if you have a clue,
    this is my my.cnf
    [mysqld]
    user = mysql
    datadir = /var/lib/mysql
    pid-file = /var/run/mysqld/mysqld.pid
    socket = /var/lib/mysql/mysql.sock
    old_passwords = 1
    #skip-innodb
    innodb_data_home_dir = /var/lib/mysql/
    innodb_data_file_path = ibdata1:10M:autoextend
    innodb_file_per_table = 1
    innodb_buffer_pool_size = 500M
    innodb_additional_mem_pool_size = 20M
    innodb_log_file_size = 125M
    innodb_log_buffer_size = 30M
    innodb_flush_log_at_trx_commit = 1
    max_connections = 5000
    interactive_timeout = 20
    max_allowed_packet = 90M
    wait_timeout = 20
    table_cache = 10M
    sort_buffer = 20M
    read_buffer_size = 20M
    tmp_table_size = 96M
    read_rnd_buffer_size = 20M
    key_buffer = 16M
    key_buffer_size = 32M
    thread_stack = 128K
    thread_cache_size = 64
    query_cache_limit = 20M
    query_cache_size = 64M
    query_cache_type = 1
    join_buffer_size = 512K
    log_slow_queries = /var/log/mysql/mysql-slow.log
    [mysql.server]
    user=mysql
    basedir=/var/lib
    [mysqld_safe]
    log-error=/var/log/mysqld.log
    pid-file=/var/run/mysqld/mysqld.pid
  • richlv
    • Oct 2005
    • 3112
    could it be that your server is overloaded ?
    what is the load, what is iowait value ?
