Good afternoon,
I got a little problem but after working half the day on it, it's becoming a bit frustrating. The problem looks like this, I already tried a lot of solution possibilites posted here in the boards:
Zabbix doesn't show me any graphs (Custom created graphs and simple graphs from "Latest data"). If I have a look at the "Latest data" section, I would get all my data, also in the legend of custom created graphs. But in detail, there are no graphs showing the trend, except data like "maximum disk space", also constant factors.
The variable data get never shown up, but it had worked this morning.
I recently set memory_limit in php.ini up to 128 and 256M, but no effect. Other solutions posted in the board I found, did also take no effect, like checking configuration.
Never the less, I suppose, that the memory is out of range or someting like that. I would be very pleased, if someone does have an helpful idea
Thanks a lot,
Luximinator
The variable data get never shown up, but it had worked this morning.I recently set memory_limit in php.ini up to 128 and 256M, but no effect. Other solutions posted in the board I found, did also take no effect, like checking configuration.
Thanks a lot,
Luximinator
