Not found Curl library with Zabbix 1.6.5 on RHEL4
  • iam33
    • Jul 2009
    • 24
    Hi! thnaks in advance!
    I´m trying to install the server and when I execute:
    ./configure --enable-server --enable-agent --with-mysql --with-net-snmp --with-jabber --with-libcurl
    I obtain the next error:
    checking for curl-config... /usr/bin/
    configure: error: Not found Curl library
    If I try whith the route of libcurl
    ./configure --enable-server --enable-agent --with-mysql --with-net-snmp --with-jabber --with-libcurl=/usr/bin/
    I obatin the same error...abd with --enable-static param....
    I probed with:
    ./configure --enable-server --enable-agent --with-mysql --with-net-snmp --with-jabber --with-libcurl=/usr/bin/curl-config
    and the error changed:
    checking for main in -lcurl... no
    configure: error: Not found libcurl library
    And with:
    ./configure --enable-server --enable-agent --with-mysql --with-net-snmp --with-jabber --with-libcurl=/usr/bin/curl-config --enable-static
    checking for main in -lgnutls ... no
    configure: error: Not found gnutls library
    Help me please!!!
    rpm -qa |grep curl
    libcurl4-7.19.4-1
    curl-7.19.4-1
    libcurl4-devel-7.19.4-1
    curl-config --libs
    -lcurl -lidn -lssh2 -lssl -lcrypto -lldap -L/usr/kerberos/lib -lgssapi_krb5 -lkrb5 -lk5crypto -L/usr/kerberos/lib -lgssapi_krb5 -lkrb5 -lk5crypto -lz
    curl-config --cflags
     curl-config --version
    libcurl 7.19.4
  • pesadilla
    • Nov 2006
    • 69
    not found gnutls library
    Originally posted by iam33
    And with:
    see the problem now is gnutls
    • dani
      • Jun 2009
      Hi
      You can find compiled/source rpm for centos 4 (made for SME server 7 which is based on centos 4) here:
      (just grab the zabbix-* rpm, do not bother with smeserver-zabbix-* which are specific for the SME Server distribution)
      And you can look here:
      if you want the pre-compiled rpm for the pgsql/sqlite variant.
      Cheers, Daniel
      • iam33
        • Jul 2009
        • 24
        Thanks for your answers!
        When I can test it, I´ll say you the results...
        • iam33
          • Jul 2009
          • 24
          http://sme-mirror.firewall-services....ibs/i386/RPMS/
          http://sme-mirror.firewall-services....ontribs/SRPMS/
          ...But....what packages must I install? all zabix packages?
          • dani
            • Jun 2009
            Well, that depend on what you want to install. If you want to install a zabbix server with mysql support, you need to download:
            and if you want the web interface on the same server, you also need:
            http://sme-mirror.firewall-services....4.sme.i386.rpm
            Download all these rpms in a local folder, then run
            yum localinstall ./zabbix*.rpm
            Cheers
            • iam33
              • Jul 2009
              • 24
              so...cause, I want to install all like:
              I must install all pacakes without refers proxy, mustn´t I?
              • dani
                • Jun 2009
                If you also want the agent, add this:
                • iam33
                  • Jul 2009
                  • 24
                  Dani,
                  Thousand thanks for your help!!! today I won´t try it, maybe tomorrow, and I will answer you how it was...
                  • iam33
                    • Jul 2009
                    • 24
                    I´m just installing the Zabbix server with rpms, but when I´m going to install zabix-server rpm ... It ask me for "zabbix-server-implementation"
                    rpm -ivh zabbix-server-1.6.5-1.el4.sme.i386.rpm
                    warning: zabbix-server-1.6.5-1.el4.sme.i386.rpm: V3 DSA signature: NOKEY, key ID 1e9c9308
                    error: Failed dependencies:
                            zabbix-server-implementation = 1.6.5-1.el4.sme is needed by zabbix-server-1.6.5-1.el4.sme.i386
                    Where Can I obtain it?
                    • dani
                      • Jun 2009
                      This is because you first need to install the package called zabbix-server-mysql. But you should really considere using yum instead of rpm as it'll resolve all the dependencies even when you install local packages:
                      download everything in a local directory with wget, then go in this directory and run:
                      yum localinstall ./*.rpm
