zabbix[queue] exploded since upgrade to zabbix 1.6.5
  • rrr
    • Sep 2007
    • 100
    Since upgrade from 1.6.4 to 1.6.5 the value of zabbix[queue] exploded, while displaying normal (low) queue-values at the queue-page.
    The first picture shows the the zabbix[queue]-value, which is 250 in average before upgrade and 1100 in average after the upgrade.
    The second picture shows the queue-page AFTER the upgrade, which looks quite normal, but the zabbix[queue] isn't normal...
    Which is the right value? The queue-values on the queue-page, or the zabbix[queue]-value? And how do I fix it?
  • Andreas Bollhalder
    • Apr 2007
    • 144
    I'm faced with the same problem. After upgrade from 1.6.4 to 1.6.5 I had a lot of outstanding items in the queue. I realized it, after the last Sunday night. I got a bunch of messages, that the agent ping did not return.
    Currently, I have increased the "StartPollers" and "StartTrappers" to 8 and under "Administration" -> "Queue" in the frontend, the values are fine again. But I have to investigate more, because with some higher values (10/10), the ZABBIX server died after around of 24h uptime... MySQL connections aren't eated up and the MySQL server shouldn't be the problem (my CPU usage is <5%, RAM is OK).
    I'm using the database cache of ZABBIX ("StartDBSyncers=1" in the server config).
    Are there others experience similar problems with 1.6.5 ?
    Andreas
    Zabbix statistics
    Total hosts: 380 - Total items: 12190 - Total triggers: 4530 - Required server performance: 224.2
