Weird icmpping behavior from zabbix-proxies (v1.6)
  • Sawn
    • Sep 2008
    We have a setup constitued of one zabbix-server, five proxies and two MySQL servers (master/slave in replication).
    All (server and proxies) are Zabbix (from sources) v1.6 under Debian Etch x86.
    Everything was working fine since last september.
    Since a few days, we have noticed a weird behavior from one of our proxy.
    This proxy is monitoring ~150 Hyper-V VM, there are about thirty hosts being declared as "down" after an icmpping check.
    Problem is : those hosts are not down.
    Here is some tests we performed from the concerned proxy :
    - ping -c1000 from the proxy to one of the "false positive" IP address : no packet lost.
    - fping from the proxy to the same host : all ok
    - traceroute from the proxy to the host : ok
    - moving monitored hosts from this proxy to another : problem repeat itself on the other proxy
    Here is what we saw from zabbix_proxy.log (debug=4 with a tail -f and grep -A3 on the hostname) :
                            "host":"hostname.domainname",
                            "key":"icmpping",
                            "clock":1247129052,
                            "value":"0"},
                            "key":"icmpping",
                            "clock":1247129082,
                            "value":"0"},
                            "key":"tcp,3389",
                            "clock":1247129103,
                            "value":"1"},
                            "key":"icmpping",
                            "clock":1247129112,
                            "value":"0"},
                            "key":"icmpping",
                            "clock":1247129142,
                            "value":"0"},
                            "key":"tcp,3389",
                            "clock":1247129163,
                            "value":"1"},
    And here is a fping from the same proxy :
    # fping -c5 hostname.domainname
    hostname.domainname : [0], 84 bytes, 0.96 ms (0.96 avg, 0% loss)
    hostname.domainname : [1], 84 bytes, 0.75 ms (0.85 avg, 0% loss)
    hostname.domainname : [2], 84 bytes, 0.93 ms (0.88 avg, 0% loss)
    hostname.domainname : [3], 84 bytes, 0.59 ms (0.80 avg, 0% loss)
    hostname.domainname : [4], 84 bytes, 0.76 ms (0.79 avg, 0% loss)
    hostname.domainname : xmt/rcv/%loss = 5/5/0%, min/avg/max = 0.59/0.79/0.96
    Any idea ?
  • froztbyte
    • Apr 2009
    • 16
    Not quite the same with me, but also some strange behaviour with monitoring via proxies. I've got hosts that I monitor in networks that I have very high latency to (>1500ms latency) and quite a few hosts start to indicate packetloss to varying degrees in the ZABBIX interface on my master server, but when I log into my proxy and run checks from there I don't get the same problem. This leads me to believe that ZABBIX is somehow making decisions about the data it's getting in via the proxies, perhaps substituting a value of '0' if it doesn't get all the data in during the sync period. This doesn't happen to all hosts, though. Anyone maybe seen this happening and perhaps have a solution?
    • Sawn
      • Sep 2008
      More informations :
      When I set the problematic hosts to be monitored directly by the Zabbix Master (server on which zabbix_server runs), the icmpping status is correct.
      But if i set them back on the proxy, after a few minutes, they are seen as down again.
      • Sawn
        • Sep 2008
        We found the problem, it had nothing to do with Zabbix.
        I've a script which synchronise an SQL Server database with Zabbix (add/delete hosts & templates) but some ip addresses in the SQL Server database contain space after the IP.
        Those spaces where replicated into Zabbix causing the hosts to be seen as down
