How To install Zabbix-1.0 on Solaris 10 x86
  • ltavenne
    • Aug 2005
    First, I installed the following free packages from sunfreeware
    expat, libiconv, gdbm, db-4.2.52.NC, gcc, gnu tar, libxml2, zlib, libpng, freetype, jpeg, xpm, fontconfig, gd
    then I used
    mysql-max-3.23.58-pc-solaris2.8-i386
    follow documentation about installation of mysql
    apache_1.3.27
    ./configure --prefix=/usr/local/apache --enable-shared=max --enable-module=so
    make
    make install
    php-4.3.5
    ./configure --prefix=/usr/local/php --with-apxs=/usr/local/apache/bin/apxs --with-mysql=/usr/local/mysql --enable-track-vars --with-xml --with-zlib --with-zlib-dir=/usr/local/lib --with-gd --with-jpeg-dir=/usr/local/lib --with-png-dir=/usr/local/lib
    make
    make install
    net-snmp-5.0.10.2
    ./configure
    make
    make install
    fping-2.2b2
    ./configure
    make
    make install
    chmod u+s /usr/local/sbin/fping
    zabbix-1.0
    ./configure --with-mysql=/usr/local/mysql --with-net-snmp
    make
    then follow documentation about installation of zabbix
  • nbctcp
    • Apr 2005
    I already success install zabbix in Solaris 10 local zone.
    Here some of my tips. Maybe you can get some idea.
    But I saw the graphic value for all localzone for disk, proc, free mem usage are all the same for all zone. I think that one because all local zone sharing the same mem, proc and disk.
    I might be wrong.
    I install all pkg in /opt/csw because that location is default pkg location for blastwave pkg. I can't use sunfreeware one, because it default location is in /usr/local and that usr is read only in local zone, unless you want remove /usr in inherited pkg, but that mean it will copy all /usr from global zone to local zone
    GD
    -download GD from http://www.boutell.com/gd/
    APACHE
    # groupadd apache
    # useradd -d /opt/csw/apache -g apache -s /bin/false apache
    # cd httpd-2.0.54
    # ./configure --prefix=/opt/csw/apache --with-mpm=prefork --disable-charset-lite --disable-include --disable-env --disable-status --disable-autoindex --disable-asis --disable-negotiation --disable-imap --disable-actions --disable-userdir --enable-so
    # gmake
    # umask 022
    # gmake install
    # chown -Rf apache:apache /opt/csw/apache
    MYSQL
    # groupadd mysql
    # useradd -g mysql -d /var/empty -c "MySQL Server" -s /bin/false mysql
    # gtar -zxf mysql-4.1.14.tar.gz
    # cd mysql-4.1.14
    # export LDFLAGS='-R/opt/csw/lib'
    # ./configure --prefix=/opt/csw/mysql --localstatedir=/var/mysql
    # gmake;gmake install
    # cp /opt/csw/mysql/share/mysql/my-large.cnf /etc/my.cnf
    # vi /etc/my.cnf
    -comment out log-bin
    # /opt/csw/mysql/bin/mysql_install_db
    # chown -R mysql:mysql /var/mysql
    # cp /opt/csw/mysql/share/mysql/mysql.server /opt/csw/mysql/bin/
    # /opt/csw/mysql/bin/mysql.server start
    PHP5
    # cd php-5.0.5
    # ./configure --prefix=/opt/csw --with-apxs2=/opt/csw/apache/bin/apxs --with-mysql=/opt/csw/mysql --with-gd --with-zlib=/opt/csw
    # cp php.ini-recommended /opt/csw/lib/php.ini
    # vi /opt/csw/lib/php.ini
    - ;include_path = ".:/php/includes"
    + include_path = ".:/php/includes:/opt/csw/lib/php"
    ZABBIX SERVER
    -download and install fping from www.blastwave.org
    # mkdir /opt/csw/apache/htdocs/zabbix
    -compile zabbix server
    # ./configure --prefix=/opt/csw --with-mysql=/opt/csw/mysql --without-net-snmp;gmake
    # chown zabbix:zabbix bin/*
    # cp -p bin/zabbix* /opt/csw/bin/
    # crle -u -l /opt/csw/mysql/lib/mysql:/opt/csw/lib
    -Note PHP5 is not supported in zabbix 1.0, we need to change in
    - allow_call_time_pass_reference = Off
    + allow_call_time_pass_reference = On
    # vi /opt/csw/apache/htdocs/zabbix/include/config.inc.php
    before the last line "?>" insert these
    if (!isset($HTTP_POST_VARS) && isset($_POST))
    $HTTP_POST_VARS = $_POST;
    $HTTP_GET_VARS = $_GET;
    $HTTP_SERVER_VARS = $_SERVER;
    $HTTP_COOKIE_VARS = $_COOKIE;
    $HTTP_ENV_VARS = $_ENV;
    $HTTP_POST_FILES = $_FILES;
