Hi all,
We got several HP Procurve switch, I'm using HP Procurve template.
It works like a charm except for one single switch, I don't understand why because all the switch are the same model and others switch does not complain at all.
In /tmp/zabbix-server.log I got this :
It seems there is an issue with delta function
Any clues please ?
31061:20090721:115312 Expression [{13925}>150000] for item [26051][HP Procurve 2626:ifInOctets18] cannot be evaluated: unable to get function value: lastvalue IS NULL for function [13925][HP Procurve 2626:ifInOctets18.delta(0)]
31061:20090721:115312 Expression [{13985}>150000] for item [26111][HP Procurve 2626:ifOutOctets26] cannot be evaluated: unable to get function value: lastvalue IS NULL for function [13985][HP Procurve 2626:ifOutOctets26.delta(0)]
31062:20090721:115315 Expression [{13926}>150000] for item [26052][HP Procurve 2626:ifInOctets19] cannot be evaluated: unable to get function value: lastvalue IS NULL for function [13926][HP Procurve 2626:ifInOctets19.delta(0)]
31063:20090721:115315 Expression [{13927}>150000] for item [26053][HP Procurve 2626:ifInOctets2] cannot be evaluated: unable to get function value: lastvalue IS NULL for function [13927][HP Procurve 2626:ifInOctets2.delta(0)]
31064:20090721:115316 Expression [{13928}>150000] for item [26054][HP Procurve 2626:ifInOctets20] cannot be evaluated: unable to get function value: lastvalue IS NULL for function [13928][HP Procurve 2626:ifInOctets20.delta(0)]
31061:20090721:115316 Expression [{13930}>150000] for item [26056][HP Procurve 2626:ifInOctets22] cannot be evaluated: unable to get function value: lastvalue IS NULL for function [13930][HP Procurve 2626:ifInOctets22.delta(0)]
31060:20090721:115317 Expression [{13929}>150000] for item [26055][HP Procurve 2626:ifInOctets21] cannot be evaluated: unable to get function value: lastvalue IS NULL for function [13929][HP Procurve 2626:ifInOctets21.delta(0)]
31060:20090721:115317 Expression [{13989}>150000] for item [26115][HP Procurve 2626:ifOutOctets3] cannot be evaluated: unable to get function value: lastvalue IS NULL for function [13989][HP Procurve 2626:ifOutOctets3.delta(0)]
31062:20090721:115318 Expression [{13931}>150000] for item [26057][HP Procurve 2626:ifInOctets23] cannot be evaluated: unable to get function value: lastvalue IS NULL for function [13931][HP Procurve 2626:ifInOctets23.delta(0)]
31063:20090721:115319 Expression [{13932}>150000] for item [26058][HP Procurve 2626:ifInOctets24] cannot be evaluated: unable to get function value: lastvalue IS NULL for function [13932][HP Procurve 2626:ifInOctets24.delta(0)]
31064:20090721:115319 Expression [{13933}>150000] for item [26059][HP Procurve 2626:ifInOctets25] cannot be evaluated: unable to get function value: lastvalue IS NULL for function [13933][HP Procurve 2626:ifInOctets25.delta(0)]
31060:20090721:115321 Expression [{13934}>150000] for item [26060][HP Procurve 2626:ifInOctets26] cannot be evaluated: unable to get function value: lastvalue IS NULL for function [13934][HP Procurve 2626:ifInOctets26.delta(0)]
31064:20090721:115326 Expression [{13938}>150000] for item [26064][HP Procurve 2626:ifInOctets3] cannot be evaluated: unable to get function value: lastvalue IS NULL for function [13938][HP Procurve 2626:ifInOctets3.delta(0)]
31061:20090721:115326 Expression [{14000}>150000] for item [26126][HP Procurve 2626:ifOutOctets4] cannot be evaluated: unable to get function value: lastvalue IS NULL for function [14000][HP Procurve 2626:ifOutOctets4.delta(0)]
31060:20090721:115339 Expression [{13949}>150000] for item [26075][HP Procurve 2626:ifInOctets4] cannot be evaluated: unable to get function value: lastvalue IS NULL for function [13949][HP Procurve 2626:ifInOctets4.delta(0)]
31062:20090721:115339 Expression [{14011}>150000] for item [26137][HP Procurve 2626:ifOutOctets5] cannot be evaluated: unable to get function value: lastvalue IS NULL for function [14011][HP Procurve 2626:ifOutOctets5.delta(0)]
31060:20090721:115343 Expression [{14014}>150000] for item [26140][HP Procurve 2626:ifOutOctets6] cannot be evaluated: unable to get function value: lastvalue IS NULL for function [14014][HP Procurve 2626:ifOutOctets6.delta(0)]
Any clues please ?
