I have a zabbix installation that's been up for about a month, collecting data and generally working very well except recently I noticed the dates on the audit logs page are showing up as, for example, "0000.Jul.22 11:32:10" with the year being "0000."
Not sure how to add screen shots, but here's what a typical line of the audit log shows via the web frontend:
I took a look in the database and everything seemed fine:
With these entries corresponding to the ones from the web interface above. I converted the timestamps and they convert to proper 2009 dates.
Has anyone come across this situation? I have America/Toronto set up as my timezone although any problems here would mean the entire date and time should be off, not just the year.
This also manifests itself into a few other sections of the frontend, such as when generating an availability report, the year is reported as 0000 as well.
Time User Resource Action Details 0000.Jul.22 11:32:10 guest User Login Correct login [XXXX] 0000.Jul.22 10:40:31 guest User Login Correct login [XXXX] 0000.Jul.21 17:03:26 XXXX Action Updated Actions [5,6] disabled
mysql> select * from auditlog order by auditid desc limit 10; +---------+--------+------------+--------+--------------+-------------------------------------------------------+ | auditid | userid | clock | action | resourcetype | details | +---------+--------+------------+--------+--------------+-------------------------------------------------------+ | 1370 | 2 | 1248276730 | 3 | 0 | Correct login [XXXX] | | 1369 | 2 | 1248273631 | 3 | 0 | Correct login [XXXX] | | 1368 | 3 | 1248210206 | 1 | 5 | Actions [5,6] disabled |
