Trigger conflict
  • xibbaz
    • Jun 2009
    • 74
    Trigger conflict
    Is this a Bug? I have exported a template and removed from the xml only the items and triggers I wanted and thus created a new template. In zabbix, I deleted those items from the original template. When I imported the new template in combination with the old one, it tells me there is a conflict.
    I suspect that deleting the items do not delete the associated triggers and they are still in the database but don't show up in the GUI.
    Either the GUI should show those triggers even if their items (or some of) no longer exist, or when you delete an item, the associated trigger should also be deleted.
    I ought for the first option.
    Or at least, it would help greatly if the confliting part of the templates would be shown somewhere.
  • xibbaz
    • Jun 2009
    • 74
    Still having this confilct between templates.
    To test my new template, I unliked the host from the old template and added the new one. Hold and behold, the old template items still show up in the metric screen.
    What is going on?
