Using Zabbix 1.6.4 on RHEL5 x86_64 ; php-5.1.6-23.el5
Using MySQL A.10.00-5.0.45.001 on HP-UX 11.23
Created new Template: "LSKN_Template_ICMP-Ping"
Selected Template: "Template_Standalone"
Checked Item: "ICMP Ping"
Pressed: "Copy selected to ..."
Checked Template: "LSKN_Template_ICMP-Ping" as target
Pressed: "Copy"
Screen will rebuild to Menu and Window history. Nothing more.
Database transaction:
Database configuration:
Seems, not all needed transactions send to database.
Following error message in httpd-log:
Any ideas ?
Pressed: "Copy"
090728 7:30:25 1267 Init DB zabbix1p
1267 Query SELECT * FROM nodes WHERE nodetype=1 ORDER BY nodeid
1267 Query SELECT u.*,s.* FROM sessions s,users u WHERE s.sessionid='d711dc38efbc3dea13f9c48875c19f82' AND s.status=0 AND s.userid=u.userid AND ((s.lastaccess+u.autologout>1248759025) OR (u.autologout=0)) AND (u.userid div 100000000000000) in (0)
1267 Query SELECT MAX(g.gui_access) as gui_access FROM usrgrp g, users_groups ug WHERE ug.userid=3 AND g.usrgrpid=ug.usrgrpid
1267 Query SELECT g.usrgrpid FROM usrgrp g, users_groups ug WHERE ug.userid = 3 AND g.usrgrpid = ug.usrgrpid AND g.users_status = 1 limit 1
1267 Query UPDATE sessions SET lastaccess=1248759025 WHERE sessionid='d711dc38efbc3dea13f9c48875c19f82'
1267 Query SELECT * FROM nodes WHERE nodeid=0
1267 Query SELECT nodeid FROM nodes WHERE (nodeid IN (-1))
1267 Query SELECT value_id, value_int, value_str, type FROM profiles WHERE userid=3 AND idx='web.menu.view.last' ORDER BY profileid ASC
1267 Query SELECT value_id, value_int, value_str, type FROM profiles WHERE userid=3 AND idx='web.menu.cm.last' ORDER BY profileid ASC
1267 Query SELECT value_id, value_int, value_str, type FROM profiles WHERE userid=3 AND idx='web.menu.reports.last' ORDER BY profileid ASC
1267 Query SELECT profileid FROM profiles WHERE userid=3 AND idx='web.menu.config.last'
1267 Query UPDATE profiles SET value_id=0, value_int=0, value_str='items.php', type=3, source='' WHERE userid=3 AND idx='web.menu.config.last'
1267 Query SELECT value_id, value_int, value_str, type FROM profiles WHERE userid=3 AND idx='web.menu.config.last' ORDER BY profileid ASC
1267 Query SELECT value_id, value_int, value_str, type FROM profiles WHERE userid=3 AND idx='web.menu.admin.last' ORDER BY profileid ASC
1267 Query SELECT * FROM config WHERE (configid div 100000000000000) in (0)
1267 Query SELECT value_id,value_int,value_str,source,type FROM profiles WHERE userid=3 AND idx='web.history.0' ORDER BY profileid ASC
1267 Query SELECT value_id,value_int,value_str,source,type FROM profiles WHERE userid=3 AND idx='web.history.1' ORDER BY profileid ASC
1267 Query SELECT value_id,value_int,value_str,source,type FROM profiles WHERE userid=3 AND idx='web.history.2' ORDER BY profileid ASC
1267 Query SELECT value_id,value_int,value_str,source,type FROM profiles WHERE userid=3 AND idx='web.history.3' ORDER BY profileid ASC
1267 Query SELECT value_id,value_int,value_str,source,type FROM profiles WHERE userid=3 AND idx='web.history.4' ORDER BY profileid ASC
1267 Query SELECT value_id, value_int, value_str, type FROM profiles WHERE userid=3 AND idx='web.items.showdisabled' ORDER BY profileid ASC
1267 Query SELECT value_id, value_int, value_str, type FROM profiles WHERE userid=3 AND idx='web.items.php.sort' ORDER BY profileid ASC
1267 Query SELECT value_id, value_int, value_str, type FROM profiles WHERE userid=3 AND idx='web.items.php.sortorder' ORDER BY profileid ASC
1267 Query SELECT profileid FROM profiles WHERE userid=3 AND idx='web.items.php.sort'
1267 Query UPDATE profiles SET value_id=0, value_int=0, value_str='i.description', type=3, source='' WHERE userid=3 AND idx='web.items.php.sort'
1267 Query SELECT profileid FROM profiles WHERE userid=3 AND idx='web.items.php.sortorder'
1267 Query UPDATE profiles SET value_id=0, value_int=0, value_str='ASC', type=3, source='' WHERE userid=3 AND idx='web.items.php.sortorder'
1267 Query SELECT value_id, value_int, value_str, type FROM profiles WHERE userid=3 AND idx='web.items.filter.enabled' ORDER BY profileid ASC
1267 Query SELECT value_id, value_int, value_str, type FROM profiles WHERE userid=3 AND idx='web.items.filter.selection_mode' ORDER BY profileid ASC
1267 Query SELECT value_id, value_int, value_str, type FROM profiles WHERE userid=3 AND idx='web.items.filter.host' ORDER BY profileid ASC
1267 Query SELECT value_id, value_int, value_str, type FROM profiles WHERE userid=3 AND idx='web.items.filter.description' ORDER BY profileid ASC
1267 Query SELECT value_id, value_int, value_str, type FROM profiles WHERE userid=3 AND idx='web.items.filter.key' ORDER BY profileid ASC
1267 Query SELECT DISTINCT n.nodeid, n.name as node_name, h.hostid, h.host, min(r.permission) as permission, ug.userid FROM hosts h LEFT JOIN hosts_groups hg ON hg.hostid=h.hostid LEFT JOIN groups g ON g.groupid=hg.groupid LEFT JOIN rights r ON r.id=g.groupid LEFT JOIN users_groups ug ON ug.usrgrpid=r.groupid and ug.userid=3 LEFT JOIN nodes n ON (h.hostid div 100000000000000)=n.nodeid WHERE (h.hostid div 100000000000000) in (0) GROUP BY h.hostid,n.nodeid,n.name,h.host,ug.userid ORDER BY n.name,n.nodeid, h.host, permission, ug.userid
1267 Query SELECT profileid FROM profiles WHERE userid=3 AND idx='web.items.showdisabled'
1267 Query UPDATE profiles SET value_id=0, value_int=1, value_str='', type=2, source='' WHERE userid=3 AND idx='web.items.showdisabled'
1267 Query begin
1267 Query SELECT itemid,description,key_,hostid,delay,history,status,type,snmp_community,snmp_oid,value_type,trapper_hosts,snmp_port,units,multiplier,delta,snmpv3_securityname,snmpv3_securitylevel,snmpv3_authpassphrase,snmpv3_privpassphrase,formula,trends,logtimefmt,valuemapid,delay_flex,params,ipmi_sensor,templateid FROM items WHERE itemid=17371
1267 Query SELECT DISTINCT app.applicationid as result FROM applications app, items_applications ia WHERE app.applicationid=ia.applicationid AND (ia.itemid IN (17371))
[client] port = 3306 socket = /tmp/mysql.sock [mysql] no-auto-rehash [mysqld] port = 3306 socket = /tmp/mysql.sock datadir = /doku1p/mysql.db/mysql bind-address = 0.0.0.0 key_buffer=16M max_allowed_packet=1M sort_buffer=512K net_buffer_length=8K myisam_sort_buffer_size=8M log-error = /doku1p/mysql.log/doku1p.err innodb_data_home_dir = /doku1p/mysql.db/mysql innodb_log_group_home_dir = /doku1p/mysql.db/mysql innodb_flush_log_at_trx_commit=1 innodb_log_archive=0 query_cache_size=16M tmp_table_size=64M max_heap_table_size=32M thread_cache_size=10 table_cache=128 innodb_buffer_pool_size=256M innodb_additional_mem_pool_size=20M innodb_lock_wait_timeout=180 innodb_file_io_threads=4 innodb_thread_concurrency=6 thread_concurrency=2 log = /doku1p/mysql.log/doku1p.log [mysqld_safe] datadir = /doku1p/mysql.db/mysql [mysqldump] quick set-variable = max_allowed_packet=16M [isamchk] set-variable = key_buffer=20M set-variable = sort_buffer=20M set-variable = read_buffer=2M set-variable = write_buffer=2M [myisamchk] set-variable = key_buffer=20M set-variable = sort_buffer=20M set-variable = read_buffer=2M set-variable = write_buffer=2M [mysqlhotcopy] interactive-timeout
==> /service/zabbix1p/var/log/httpd/ssl_error.log <== [Tue Jul 28 09:45:57 2009] [error] [client 10.100.195.57] PHP Fatal error: Call to undefined function check_db_fields() in /service/zabbix1p/share/zabbix/include/items.inc.php on line 226, referer: https://zabbix1p.dmz.polizei.niedersachsen.de/items.php
